Thomas Kimsey Thomas Kimsey Senior Moderator Location: Rochester, New Hampshire Join Date: 10/05/2013 Age: Settling Down Posts: 271 Rally Car: 1988 XRatty |
Saw this in the latest episode of launch control. Why would Vermont SportsCar risk suspension failure by attaching their knuckle/upright this way. Sure it gives you adjustability but in a Global Rallycross car I would think durability would be preferred. Those threads are never going to be good in shear.
Closer |
While they are not ideal, if they are big enough you won't have an issue. It's not the best reasoning, but sometimes big and simple wins over lightweight and complicated.
You can also get camber adjustment done very quickly, where with shims it will take a bit longer (unless you're really well prepared with a good design). Those uprights seem a little crude though , but very simple. |
I agree that it is easier. Also they look nicer than a fat stack of shims. I just think it is funny that one of the big No-Nos of suspension design ends up on well funded cars. Also shims suck to change if there is safety wire involved. |
Cosworth Paulinho Ferreira Super Moderator Location: Charlotte, NC Join Date: 03/15/2007 Age: Midlife Crisis Posts: 721 Rally Car: Honda Civic |
Thats definitely not the brightest crayon in the box to be using rods ends like that.... but its easy and cheap to fabricate, fix and replace on site. Best option would be to use uniballs but that makes it a more complicated upright design, and will need a strong kingpin.
The only think keeping that wheel from flying off is that toe arm, if that fails for some reason, it will snap the other 2 rod ends so quick that they'll never know what failed first. But shirley they know betterer |
Wait, I'm a bit confused. How is the toe arm different? What am I missing?
Is the thought that the rod ends would rip from the suspension arms? Or is it the little U channels the ends go into, and that bolt being sheared? Welcome to the cult of JVL drink the koolaid or be banned. |
The issues with rod ends in bending is the threads. Threaded material is good in taking forces in tension and compression but not really in bending. What happens is the threaded part bends and deforms. It may even bend and then you get shearing loads at the threads and the result is the rod end breaking off at the threads. You can also have distortion in the spherical and cause that to seize. In road race cars the main cause of rod end failure is braking since the super sticky tires facilitate massive grip and massive load. In rally applications you have the grip and the track roughness to worry about. |
The toe link is a much smaller rod end, and is usually the first thing to break when there is an impact. When the toe link breaks the wheel usually slams into the control arm, which either bends/breaks or breaks the upper and lower rod-end mounts.
I also like how the rod end is taking all the drive and braking forces (probably much higher than suspension loads) in the weakest direction. |
looks like the front end of a late model dirt car, in away.
they never get to far from the service crew, so it most work for them I would rather drive a slow car fast as a fast car slow! first rule of cars: get what makes you happy, your the one paying for it! |
So, as they're mounted vertically, how is this different than rod ends suspending a live axle? Or am I still missing something? I see metal on both sides of the rod end, so the bolt is supported the same, and it's moving in it's larger range of motion orientation. Does this just have more force than the live axle would transfer? Welcome to the cult of JVL drink the koolaid or be banned. |
Ah, so is this problem design related, or execution related? Could they have made the mounts beefier and solved the problems? Your last bit there, do you mean that instead of the rod being able to move freely (as its in line for travel) the forces are going through it through it's smaller range of motion? Does that question make sense? Welcome to the cult of JVL drink the koolaid or be banned. |
Clayto Clayton McCrary Junior Moderator Location: Olympia,WA Join Date: 07/04/2013 Age: Possibly Wise Posts: 161 Rally Car: XRatty purchased. Now build it!! |
