2.0 Ecoboost to RWD, A Brief How-To
Posted by Robert Culbertson
Robert Culbertson
Out of this dumpster fire
Re: 2.0 Ecoboost to RWD, A Brief How-To
May 21, 2015 01:21PM
Meh, there are turbo miatas with more power/torque out there with success running the 6spd. The first trans always had a loud 3rd and shifted a bit clunky, we still aren't sure if that was normal or not. If the 2nd trans goes, well we now have more than just an isolated case. We will actually have a very open case, with gear teeth everywhere.
T5 swap is on the horizon though. All the off the shelf bellhousing are less than ideal though (Not a big fan of hydraulic-annular throw out bearings).
May 21, 2015 01:26PM
Robert Culbertson
Why is that?
Robert Culbertson
May 21, 2015 01:54PM
My only experience is with the Ford truck TO bearings. When they start leaking, you have to pull the trans to replace them. One of the replacements I installed leaked immediately, so trans back out again.
They can also be a pain to bleed (mainly access to the bleeder). Slaves on the outside of the bellhousing... so much easier to replace if they fail.
May 21, 2015 02:05PM
bleeding can be resolved. But a regular old slave would be easier to replace. I didn't think they were particularly failure prone.
Robert Culbertson
May 21, 2015 03:13PM
New ones probably are not failure prone (my experiences were with 80s/90s Ford trucks), but if they do fail... it really sucks.
May 21, 2015 04:41PM
The clutch fork and pivot are a regular failure point for me on the older 5 speeds. That requires removing the trans to fix too. Reinforcing only makes them last a bit longer, not really a permanent fix.
Robert Culbertson
May 21, 2015 05:44PM
So what is the solution? Break clutch forks or risk a leaking hydro-TO bearing?
Maybe the Tilton ones are actually nice...?
May 21, 2015 06:51PM
I'll take a hydraulic throwout bearing any day. Millions of cars out there have them and they aren't major failure items. Basically every front drive GM/SAAB since the Ecotec era started uses one, and even a little before that. Every front drive Volvo. Buncha others, too.
The aftermarket ones are also very nice. No more linkage flex taking away pedal travel. I think I have it bad with clutch fork flex and pivor ball flex, the American iron guys have Z-bars that twist and frame mounts that flex too, in addition to the flexy stamped forks, and then they also have relative motion between the frame and engine to worry about too. Hydraulic throwout bearings solve ALL of that. The first time I experienced one (a GTO with a Richmond 6 speed) I was utterly shocked - it was a 60s car with a clutch pedal that didn't feel like complete shit despite the typical oh-too-stiff pressure plate!
Haven't seen one of the aftermarket ones fail, ever. They're all metal instead of half plastic like the OEM ones.
May 21, 2015 07:09PM
Just for the record, the earliest annular slave set up I know of and have worked with is from MY75 Saab 99....Very reliable if correct brake fluid was used--DOT4---
Near immediate failure if DOT3 was used...
At least on Saabs with the clutch quickly accessible under a platic cover, swapping was quick like max 30 minutes from switch off to switch on..
Bleed screw easily reachable
The earliest of the aftermarket ones used Saab dimension seals and O rings. And Saab release bearing too.
I like 'em BUT..
I like swapping an external one with one bolt more...
May 21, 2015 07:13PM
Rebuilds are easy on the Saab:
Thats it.
May 21, 2015 08:35PM
Seen two of these type failures in the last 6 months. Not on my car, and I dont frequent shops. This was on buddies wifes cars. One involved replacing the trans that would no longer hold fluid (a saturn that was allegedly poorly maintained but the failure is common enough). I don't think there is an end all be all, but I wouldn't write off a nice hydraulic throwout based on 80's ford stuff.
John is just a cheater winking smiley
Edited 2 time(s). Last edit at 05/21/2015 08:38PM by aj_johnson.
May 21, 2015 08:39PM
And you can trust me! I'm a Professional Moderator!
May 21, 2015 08:41PM
Oh yeah? says who? I see "Mod moderator."
I's a mega moderator so I's outranking youse.
Robert Culbertson
May 22, 2015 01:01AM
If we switch to a hydro TO and it leaks, I'm holding you personally responsible. smiling smiley
May 22, 2015 09:57AM
Installer error. But if the trans is the weak point, and the only thing holding you up from strong stuff is the slave cyl... Reinvent the bellhousing this winter.
There is prize money to be had from idaho!
Edited 1 time(s). Last edit at 05/22/2015 10:00AM by aj_johnson.
