2.0 Ecoboost to RWD, A Brief How-To
Posted by Robert Culbertson
Robert Culbertson
Out of this dumpster fire
Re: 2.0 Ecoboost to RWD, A Brief How-To
July 14, 2015 05:39PM
RALLYRS
Just to verify....this was the NC Miata 6-speed(normally stock bolts to a 2.0 Mazda MZR/Duratec)
6-speed trans that went KABOOM whilst mated to the swapped in ecoboost?
Yep. Stock NC 6spd gearbox.
tdrrally
edward mucklow
July 17, 2015 11:13AM
http://www.autoblog.com/tag/project+ugly+horse/
Robert Culbertson
July 17, 2015 02:03PM
That's where we got the idea for the NC trans initially.
tdrrally
edward mucklow
July 17, 2015 06:15PM
that is where i got the idea to rally a fox body mustang
so many engine options
March 04, 2017 08:47AM
So, er, moving right along...
Is there any reason why a Ranger oil pan would not be workable with the Ecoboost? I do understand that it requires eliminating the balance shafts.
Robert Culbertson
March 04, 2017 11:37AM
The balance shaft assembly weight something like 17lbs! I definitely took it off.
I skipped the ranger pan because it was cast aluminum, but it should work just fine.
Retro-Ford has a steel rear sump duratec pan, but it's $$$.
March 04, 2017 02:28PM
Good to know. I am probably going to be picking up a core Ranger engine shortly. The engine itself is FUBAR but the RWD-specific parts should be salvageable.
The downside is, it looks like for only a little more outlay relative to an Ecoboost + controls pack + turbo-specific necessities, one could build a really kickass 2.4l motor. 2.5 block, 2.3 crank, 2.0 direct injected head (apparently this is the best Duratec starting point), decent rods/pistons/cams, the usual intake and exhaust requirements, 330+hp naturally aspirated at sane RPM. No need for porting or valvesprings or other such expenses, either.
Well, I gots TWO RX-7s now, and I could source the 2.5 block from a Mazda 6 so I could claim it is a Mazda engine...
Edited 1 time(s). Last edit at 03/04/2017 02:31PM by Pete.
fliz
Chad Eixenberger
1988 VW Golf #687
March 04, 2017 03:33PM
Is that still a requirement for anybody? I thought it was taken out a few years ago.
Robert Culbertson
March 04, 2017 04:21PM
fliz
Gotta get that Mazda contingency money yo!
March 04, 2017 05:27PM
Exactly, assuming that the windshield crack rule gets rescinded.
mekilljoydammit
No rally car yet
March 05, 2017 09:52AM
I know the 2L NA version anyway has FoMoCo cast into it so I can't imagine anyone could identify a Mazda 3 2.5 vs a Ford Fusion 2.5 block.
March 05, 2017 12:25PM
The Mazda 6 engines seem to be cheaper, probably because the super cramped engine bay means they always have broken intake manifolds and timing covers.
You ain't seen "fun" until you seen a 3.7l Mazda 6, either. I don't think you could fit a finger between the timing case and the strut tower. Step 1 in replacing the water pump, or almost anything else, is "Remove drivetrain from vehicle."
Edited 1 time(s). Last edit at 03/05/2017 12:26PM by Pete.
Robert Culbertson
March 05, 2017 05:11PM
mekilljoydammit
There's Volvo bits on the ecoboost as well.
March 05, 2017 06:26PM
Like what? Do tell!
I wasn't aware that Volvo had anything at all to do with FoMoCo enginery. Mazda made the fours, Ford made the sixes, and Volvo made the chassis.
I thought, anyway...
Mad Matt F
Matt Follett
March 05, 2017 08:37PM
Doesn't the Volvo 2.5L T5 share some with the Duratec??? Or the Duratec derived from some of it???
A quick googler... Wiki
The B5254T3 is a 2.5 L (2,522 cc) straight-five. Bore is 83 mm (3.3 in) and stroke is 93.2 mm (3.7 in) with a compression ratio of 9.0:1. It is turbocharged and intercooled with a power output of 220 PS (162 kW; 217 hp) at 5000 rpm with 320 N·m (240 lb·ft) of torque at 1500–4800 rpm. On cars with the AW55-51 automatic transmission, torque is limited in first and second gear.[131] It has VVT and uses the Bosch ME 9.0[132] engine management system.[133] Unlike previous designs, the turbocharger is integral with the exhaust manifold.
Adaptations of this engine were used by Ford, with power levels ranging from 220PS (217 bhp)[134] to 350PS (345 bhp).[135] At Ford the engine was called "Duratec-ST",[136] "Duratec ST"[137] or "Duratec RS".[138]
Applications:[139]
2005–2008 Volvo S40 II[104] badged as S40 T5
2005–2008 Volvo V50[104][140] badged as V50 T5
2007 Volvo C30 badged as C30 T5
2006[141]–2007[142] Volvo C70 badged as C70 T5
2005[143]–2011 Ford Focus[132] badged as Focus ST[144]
2009[145]–2010[146] Ford Focus badged as Focus RS[145]
2011 Ford Focus badged as Focus RS 500[135]
