http://www.autoblog.com/tag/project+ugly+horse/
I would rather drive a slow car fast as a fast car slow! first rule of cars: get what makes you happy, your the one paying for it! |
That's where we got the idea for the NC trans initially. |
So, er, moving right along...
Is there any reason why a Ranger oil pan would not be workable with the Ecoboost? I do understand that it requires eliminating the balance shafts. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Good to know. I am probably going to be picking up a core Ranger engine shortly. The engine itself is FUBAR but the RWD-specific parts should be salvageable.
The downside is, it looks like for only a little more outlay relative to an Ecoboost + controls pack + turbo-specific necessities, one could build a really kickass 2.4l motor. 2.5 block, 2.3 crank, 2.0 direct injected head (apparently this is the best Duratec starting point), decent rods/pistons/cams, the usual intake and exhaust requirements, 330+hp naturally aspirated at sane RPM. No need for porting or valvesprings or other such expenses, either. Well, I gots TWO RX-7s now, and I could source the 2.5 block from a Mazda 6 so I could claim it is a Mazda engine... Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 03/04/2017 02:31PM by Pete. |
The Mazda 6 engines seem to be cheaper, probably because the super cramped engine bay means they always have broken intake manifolds and timing covers.
You ain't seen "fun" until you seen a 3.7l Mazda 6, either. I don't think you could fit a finger between the timing case and the strut tower. Step 1 in replacing the water pump, or almost anything else, is "Remove drivetrain from vehicle." Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 03/05/2017 12:26PM by Pete. |
Like what? Do tell!
I wasn't aware that Volvo had anything at all to do with FoMoCo enginery. Mazda made the fours, Ford made the sixes, and Volvo made the chassis. I thought, anyway... Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Mad Matt F Matt Follett Infallible Moderator Location: La Belle Province, Montreal Join Date: 03/13/2006 Age: Midlife Crisis Posts: 645 Rally Car: Don't Laugh, the Justy is Fun! |
Doesn't the Volvo 2.5L T5 share some with the Duratec??? Or the Duratec derived from some of it???
A quick googler... Wiki The B5254T3 is a 2.5 L (2,522 cc) straight-five. Bore is 83 mm (3.3 in) and stroke is 93.2 mm (3.7 in) with a compression ratio of 9.0:1. It is turbocharged and intercooled with a power output of 220 PS (162 kW; 217 hp) at 5000 rpm with 320 N·m (240 lb·ft) of torque at 1500–4800 rpm. On cars with the AW55-51 automatic transmission, torque is limited in first and second gear.[131] It has VVT and uses the Bosch ME 9.0[132] engine management system.[133] Unlike previous designs, the turbocharger is integral with the exhaust manifold. Adaptations of this engine were used by Ford, with power levels ranging from 220PS (217 bhp)[134] to 350PS (345 bhp).[135] At Ford the engine was called "Duratec-ST",[136] "Duratec ST"[137] or "Duratec RS".[138] Applications:[139] 2005–2008 Volvo S40 II[104] badged as S40 T5 2005–2008 Volvo V50[104][140] badged as V50 T5 2007 Volvo C30 badged as C30 T5 2006[141]–2007[142] Volvo C70 badged as C70 T5 2005[143]–2011 Ford Focus[132] badged as Focus ST[144] 2009[145]–2010[146] Ford Focus badged as Focus RS[145] 2011 Ford Focus badged as Focus RS 500[135] |
