Pre 1950s rally car?
Posted by NoCoast
June 20, 2016 10:22AM
Ridiculous idea but if you were to build a pre 50s car for gravel, what would it be. Modern drivetrain and suspension so its mostly dimesions and cosmetic.
I've seen video of a 49 Ford Tudor drifting and I like the Hudson Brougham but 200" length and 125" wheelbase would make that one tough.
Ideas?
Re: Pre 1950s rally car?
June 20, 2016 10:35AM
Nash metropolitan wait not that was early 50s....
Edited 1 time(s). Last edit at 06/20/2016 10:35AM by Gravity Fed.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
June 20, 2016 10:55AM
I have driven a 1950 Ford which is basically the same as what you are looking at it is was terrible. Even with the flat head V8 is was slow, cumbersome, and hard to see out of. All of the ergonomics were terrible. So from a starting point I am not sure you could find something worse.
From a dimension standpoint it is basically the same size as an extended cab Ford Ranger. Might be "easiest" to just start with a truck frame and build body mounts for the shell you want to use.
Don't most of these old cars have under floor masters for the braking. So maybe racing has come full circle with the fancy floor mounted pedal boxes that everyone is drooling over.
Also there is this:
I know we are putting cages in cars, etc. But a good bit of safety is likely coming from the base cars ability to shed energy during an impact and not do thinks like impale the driver with the steering wheel.
Robert Culbertson
Out of this dumpster fire
June 20, 2016 11:03AM
I have 2 '38 Ford truck cabs and a '51 Buick sitting at my dads farm (because farms don't look right without some old cars sitting in a field).
I'd probably do something like this:
DanielSL
Daniel
2005 VW Mk. 4 Golf GTI 1.8T
June 20, 2016 11:55AM
Mercedes Benz 170 V. 1949-1955. First car built by MB to be an "S" class. I would install an S55 drivetrain, with the supercharged V8. No turbo-lag. Would be a hoot. Only a 112", so not too bad.Only about a foot longer than Mk. 3 through Mk. 7 GTi's that I'm used to.
June 20, 2016 09:34PM
Volkswagen?
Thomas Kimsey
Thomas Kimsey
1988 XRatty
June 21, 2016 08:54AM
Volvo
open | download - pv444.jpg (45.4 KB)
Paul Buck
Paul Buck
Volvo 242 in progress
June 21, 2016 09:36AM
Thomas Kimsey
Volvo
On that note...
Saab!
open | download - SAAB-190.jpg (61.8 KB)
Thomas Kimsey
Thomas Kimsey
1988 XRatty
June 21, 2016 09:50AM
Paul Buck
Thomas Kimsey
Volvo
On that note...
Saab!
The 96 isn't that old!
June 21, 2016 11:47AM
Thomas Kimsey
Volvo
Early 60s
June 21, 2016 11:51AM
Paul Buck
Thomas Kimsey
Volvo
On that note...
Saab!
Considering Saab began making cars first in November 1949 (and took cars no 3 and 7 off the line to prep for Monte Carlo) might be hard to find pre-1950s Saabs..That thing above is early 60s..
The mighty 850---with which they beat the whole world. (including Mercedes and Austin Healy works built 3,0 liter OHC sports cars--on clean asphalt)
tdrrally
edward mucklow
June 21, 2016 12:13PM
something like this; https://upload.wikimedia.org/wikipedia/commons/f/f7/BuckBaker1949OldsmobileRocket.jpg
Thomas Kimsey
Thomas Kimsey
1988 XRatty
June 21, 2016 12:17PM
Thomas Kimsey
Volvo
Early 60s
PV444 was in production in the 40s.
June 21, 2016 04:14PM
Thomas Kimsey
Thomas Kimsey
Volvo
Early 60s
OK split screen..Sorry...
Do like whassis name Ingvar Gustaffsson and shove a built B23 in and make 265 hp...It'll go good.
Edited 1 time(s). Last edit at 06/21/2016 04:19PM by john vanlandingham.
Paul Buck
Paul Buck
June 21, 2016 04:44PM
Thomas Kimsey
Paul Buck
Thomas Kimsey
Volvo
On that note...
Saab!
Never trust google image search...
But as John said, the 92 started production in 1949. Maybe they only made 4 of them in '49, still fits the question.
