Re: subaru rear sub frame
December 15, 2008 11:17PM
Tim Taylor Wrote:
> Ooooh, I want electron beam welded Ti...
NO SUBFRAME FOR YOU!!!
December 15, 2008 11:27PM
Dipis burger? Liter of cola?
CAN I GET A GOD DAMN LITER OF COLA???
"liter of cola? Do we make liter of cola?"
"Liter is french for GIVE ME SOME GOD DAMN COLA"
"Just order a large, farva"
"I dont want a large Farva........."
pikespeakgtx Wrote:
> I've now drooled all over everything on that
> subaru site.
> Dave if you've got any other sick ass car porn you
> want to share. Hook it up!
> Michael LeCompte
You mean like this?
Or how about this?
Dragons having sex with cars, you really can find anything on the internet! Thanks, Al Gore!
December 15, 2008 11:37PM
Here ya go Dave how about some Canadian car bangers...
December 16, 2008 12:29AM
> bangers...
Sweet! Kids In The Hall rule.
December 16, 2008 12:34AM
That yellow starlet is clean with the baby supra wheels.
I'd hit that shit.
December 16, 2008 09:26PM
I’m debating on how to set up the diff mounts what would you guys want? A solid
set up or a stiff bushing arm that would fit stock location?
December 16, 2008 09:32PM
Also I like the idea of the cage mount points on the top so if you want to get
hard core you can use aluminum space and bolt up through to 2 points of the cage.
December 16, 2008 10:50PM
I'd prefer a stuff ass bushing to leave a little bit of give back there. makes it a little easier if stuff is tweaked and you are trying to replace parts etc.
You could also carve a couple more holes for the control arms so we can adjust the angle of the control arms?
what are you using to model?? I work with Solidworks everyday (at a Solidworks VAR, tech support, training etc) send me some files and i can tweak too...
December 16, 2008 11:23PM
oh..btw..there are several different stock diff brackets for Subarus.
The WRX used the bar like you have in the original post.
GC SUbarus 98-01 RS's used no bracket but instead the studs on the back of the diff were very long and went direct into a bushing pressed in the x-member.
So...as long as you devise a system that bolts up to the 2 studs on the back of the diff, you are laughing.
I'd prefer if it was a nice piece with a couple bushings..
December 16, 2008 11:35PM
Its Rhino 3d. Version 4 I think (Same as what I'm using... till I learn solid works.. Engineering Graphics ftw haha)
December 17, 2008 01:56AM
The holes are in the same location send me an email and ill send you a dxf or dwg
December 17, 2008 01:58AM
the gold is for john! ha i have a few other mounting ideas and tube ideas im going
to play with
December 17, 2008 06:22AM
That looks real good. Box up the lateral arm brackets a bit more and see if you can find a way to make the rear diff mount less bendy. Also, have you thought about the front diff mount T-member? Seems a shame to use the stock piece with that fancy tubular crossmember. Plus the outer bushings for it are huge and squishy and allow lots of movement. Seems like you could design something that would use smaller, stiffer (perhaps solid) bushings that would be cheaper and easier to find than the Gr.N bushings.
December 17, 2008 08:37AM
I like it!
Remember that there are some clearance issues with the Gastank in the front side of it.
I would also seriously consider dropping a piece of tube between the "mounts" where it mounts to the chassis. I've had stock ones break in half there...
Or another piece of .250 plate would do fine...sure you could whip up a nice plasma cut piece and throw your logo in there...
