The lead seal is not a new regulation, it is 'the' regulation. Most regional events don't have access to the equipment to do it. I believe Canada requires the same. I paint the housing, screw, clamp..whatever I can. If sealed we dab the seal. I usually kept a close eye in service just so there could be no shenanigans and competitors don't have to worry what the other guy was doing.
vbares Vittorio Bares Super Moderator Location: Londonderry, NH Join Date: 04/10/2007 Age: Ancient Posts: 413 Rally Car: Audi 4k (3b conversion) |
I didn't see anything about lead seals, but definitely about the needle screws - below:
3.13.2 Restrictor Specifications 1. All turbocharged cars listed as requiring restrictors must be fitted with a restrictor fixed to the compressor housing unless the compressor air inlet internal diameter is equal to or smaller then the required restrictor internal diameter. 2. All air used for feeding the engine must pass through this restrictor. 3. The restrictor must be maintained for a minimum distance of 3 mm measured downstream of a plane perpendicular to the rotational axis situated at a maximum of 50 mm upstream of a plane passing through the most upstream extremities of the wheel blades (see Appendix B drawing 254-4). 4. The required diameter must be complied with regardless of the temperature conditions. 5. For the installation of the restrictor it is permitted to remove material from the compressor housing and to add material for the sole purpose of attaching the restrictor onto the compressor housing. 6. The restrictor must be made from a single material. 7. The restrictor may be pierced solely for the purpose of mounting and sealing, which if done must be carried out between the mounting screws, between the restrictor (or the restrictor/compressor housing attachment), the compressor housing (or the housing/flange attachment) and the turbine housing (or the housing/flange attachment) (see Appendix B drawing 254-4). 8. In case of an engine with two parallel compressors, each compressor must be limited to a maximum intake diameter of 22.6 mm. 9. Diesel engine: For vehicles with diesel engines, the restrictor must have a maximum internal diameter of 35 mm and an external diameter of 41 mm. 10. Championship Options - A championship may elect to require tighter scruitneering control of the restrictors. If so stated in the championship regulations, the following rules also apply: The external diameter of the restrictor at its narrowest point must be less than 38 mm, and must be maintained over a distance of 5 mm to each side.The mounting of the restrictor onto the turbocharger must be carried out in such a way that two screws have to be entirely removed from the body of the compressor, or from the restrictor, in order to detach the restrictor from the compressor. Attachment by means of a needle screw is not authorized. The heads of the screws must be pierced so that they can be sealed. 11. Restrictors in Group N cars must meet all Group N regulations. Edited 1 time(s). Last edit at 08/18/2011 04:54PM by vbares. |
A1337STI Alex Rademacher Godlike Moderator Location: Reno,nv Join Date: 09/10/2007 Age: Midlife Crisis Posts: 686 Rally Car: 93 GC with an 01 RS swap! |
Its proof positive if it HAS been tampered with... Of course some well establish, high end preparation shops have been reported frequently enough to posses wire and lead seals and a goodly collection of paints......but Shirley I cannot comment. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I haven't heard of that, I suppose it is possible though. We do spot checks along the route and impound the cars at finish so I really doubt if people try it. |
Toyota didn't swap out turbos, they engineered them to pass tech and still be non-compliant. Not really the same thing.
If you swap out a turbo in service it should be inspected by tech at that time. Not all events have the manpower to do that. I usually hang around service and watch. Hurst does the same. There is never a sure way that humans can't find a way to cheat, its in our nature. NASCAR, WRC and F1 have amazing tech procedures and budgets to support them and still people get caught cheating or out of compliance (I think there is a difference...intent). |
Toyota used a combination of mechanical capabilities in the restrictor plus, and here's the real trick, that extra air was enabled by installing the intake hose. So, during inspection - all aspects passed even during the rally...genius!
Yeah, as soon as the 1987 Audi 4k with locking diffs and bitchin suspenders starts threatening the front runners - I'm sure everything will be scrutinized ![]() |
Atta boy, give 'um hell !!! |
