Ian S Ian Seppanen Infallible Moderator Location: Esko, MN Join Date: 10/19/2011 Age: Settling Down Posts: 149 Rally Car: 1991 Nissan 240SX |
Ok John, here are some of the pictures you asked for. Im sure I forgot something, so you I may have to take more.
Here is the clearance I have between the strut body and the tire. We are pretty close here. I think extending the ears on the lower strut mount is a good idea to give a little more, but I think adjusting the back spacing on the wheel is also something to look into. I dont want to lose any negative camber. Might have to cut out the strut top had and move it over. The stock S13 alloys do have a very high offset, but I wont be ditching them quite yet, they have proven to be very stout. I have hit some nasty stuff with the broken suspension, and I have yet to bend a single one (knocks on wood). And they aren't so heavy either. ![]() At full droop. ![]() ![]() Room to move towards the center if absolutely needed. ![]() Not much though. ![]() Length for reference. ![]() Houston, we have a problem. Removing the springs = weight reduction? ![]() ![]() After climbing my 200 lbs self onto the strut towers and jumping up and down. There are no front springs in the car at all, just dampers. I was able to get the LF to sink a couple inches, and the RF a little less. They didnt go down smoothly either. Every time I would jump, they would clunk down just a little more. Something is very wrong with them. ![]() |
eyesoreracing Dave Coleman Junior Moderator Location: Long Beach, CA Join Date: 05/13/2007 Age: Possibly Wise Posts: 448 Rally Car: Mazda3, SE-R Spec-V, 510 |
Ian, I have a JDM mystery junkyard diff in my woman's S13. It's a factory LSD (Clutch diff, Hitachi manufacture) with a 4:38:1 R&P. The R&P will not swap between this diff and the U.S. 240 diff. The bolt diameter is different, as is the ID of ring gear. I know this because I tried to swap them (U.S. 4.08:1 is a much better match for an SR20DET). I suspect the diff originally came from an early S13 with the CA18DET, but I'm not certain of it. The axle splines were different, at least on one side, and we had to get slightly creative. Can't remember exactly how we made it work, but it involved some mixing and matching of factory parts. If you have an LSD in your car, I might be amenable to a swap, since this ratio kinda sucks for a street driven turbo car. -Dave |
<Begin excited nerdy SCC fanboi rant> Holly crap I'm talking to Dave Freaking Coleman. I miss reading your editorials in SCC, but still enjoy the stuff on Moto IQ. Keep up the good work Sir, I hope some day to run into you at a rally, though I dont know how often you race these days outside of LeMons and whatnot. Keep on keeping the geek in car geek. <end rant> Ok now that that is over, back to business. I would love to give a clutch LSD with 4.38 gears a go, but sadly I dont think you will want a welded ABS R200, or a pretty abused non ABS R200 that is non LSD. At the moment I am rather happy with the welded diff. Its not pretty or exciting, but its holding up nicely to the abuse, and in the event of a broken half shaft, I can still limp to service and continue the rally. I fear a CLSD even with heavy preload, wouldnt allow that. John will just say dont break axles, ![]() Not to mention the cost of shipping 2 diffs from nowhere land to CA would surely be obscene. In other words, I must respectfully decline. Its too bad the ring and pinions couldn't be swapped. If it is a clutch type LSD, in an R200 case, I would venture a guess that it came from a Z31 300ZX or skyline. Maybe even S12. AFAIK 4.08 was one of the shortest gear ratios you could get in the S13 or S14. Most of the JDM cars came with 3.9s. I guess I will have to keep scanning the importers for one of the R32 or R33 diffs with the 4.36 gearing. Or get the part numbers from Martin for the R&P he bought. Thanks Dave!!! |
Good to know, I will keep that in mind lol. Ever plan to make it up this way again for some stage time? |
MRWmotorsports Martin Walter Professional Moderator Location: North Gower, Ontario, Canada. Join Date: 03/01/2006 Age: Ancient Posts: 450 Rally Car: Nissan 240SX |
I went out with a flashlight and crawled under the old stock car that hasn't moved in a while. This Ring and pinion fits in an ABS housing, which should suite you well.
Part number 38100-05MB0 "Gear Set-Final" is the description. Then I wrote "2000 frontier, front" and "4.625" Tell me what you find out. -Martin. |
Hej poiki, check this out; whole axle for as low as $175 and not too far:
Year Part Model Description Miles from you Part Grade Stock# US Price Dealer Info Dist mile 2001 Front Axle Assy. Nissan Xterra 103,000 A 207157 $175 Shipman Auto Parts, Inc. USA-MN(Brainerd) E-mail 1-800-892-4779 86 miles 2003 Front Axle Assy. Nissan Frontier IN TRUCK 189,000 D08187 $200 Kadinger Salvage, Inc. - GoldSeal, ARAPro USA-WI(Downing) Request_Quote 1-800-503-8895 Request_Insurance_Quote 109 miles 2001 Front Axle Assy. Nissan Frontier ASSY,FRNT,4.636,ALSO UNDER 440 88,984 A J315 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 2003 Front Axle Assy. Nissan Frontier ASSY,FRNT,4.636,ALSO UNDER 440 5,366 A F304 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 2004 Front Axle Assy. Nissan Frontier ASSY,FRNT,4.636,ALSO UNDER 440 97,264 A M0064 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 2000 Front Axle Assy. Nissan Xterra ASSY,LESS AXLES,SE,4.63 20,981 A D210 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 2000 Front Axle Assy. Nissan Xterra ASSY,FRNT,4.63,ALSO UNDER 440 59,924 A E173 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 2000 Front Axle Assy. Nissan Xterra ASSY,FRNT,4.63,ALSO UNDER 440 88,687 A F222 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 2001 Front Axle Assy. Nissan Xterra ASSY,FRNT,4.63,ALSO UNDER 440 80,504 A H143 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 2001 Front Axle Assy. Nissan Xterra ASSY,FRNT,4.63,ALSO UNDER 440 87,000 A H363 $200 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote 118 A bunch in one place. Skip 1st and have fun! John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
While browsing for a spare transmission, I found a 180SX diff with supposidly stock 4.36 gears. So they do exist. Apparently it came from an early model CA18 180SX. It was an open diff though, and the kid wants a boat load for it. Maybe Dave is onto something
![]() SOHC engine is all tore up. Hope to have my DOHC delivered next week and I can get the block and head off to the machine shop for cleaning, honing, and pressure checking. What are everyone's opinions on bearings. I have a bunch of choices. ACL, Clevite..... I always hear people talking about these big bearing manufacturers, but what about OE Nissan. The ones I pulled out took a hell of a lot of abuse, and they didn't look all that bad. Then there are rings. So many choices. |
Bump
Any word on some of the stuff you were getting put together? Any more measurements you need? I need to know how much I will be needing to bump up my strut towers in the rear, and I dont know if we discussed what we are going to do about top mounts. Since I will be making the towers, I can do just about anything, what would you suggest? keep me posted. |
See this thread, page 10 for what i did in the rears.
http://www.rallyanarchy.com/phorum/read.php?5,38131,48930#msg-48930 I can verify the 2.5" if needed, but what I did was cut the top off, figure out the bottom mount, then mount the things up to figure our where the top needed to be re-located to. -Martin. |
alosix Jason Powers Infallible Moderator Location: Lyons, CO Join Date: 08/02/2011 Age: Midlife Crisis Posts: 326 Rally Car: 02 WRX, still to quiet, but it finished a rally |
http://ruggedrocksoffroad.com/5143-front-r200a-ring-and-pinion-gears-nissan-frontier-1997-2004-v6-by-nismo-p-5660.html?osCsid=dlm4gi2v25u9gvijsh8n9k08g5
Well now that looks entertaining for gearing. I really need to bug yukon to see if they would entertain the idea of doing a run of R160/R180/R200 R&Ps.
Russell OConnell Russell OConnell Ultra Moderator Location: WA Join Date: 12/28/2011 Age: Midlife Crisis Posts: 12 Rally Car: none |
Additional OEM transmission gear ratio info can be found in this thread.
http://www.nissanroadracing.com/showthread.php?t=3257&page=2 All KA's SOHC and DOHC 1st = 3.321 2nd= 1.902 3rd = 1.308 4th = 1.000 (Direct Drive) 5th = 0.759 (Over Drive) All S13 SR20DET's 1st = 3.321 2nd= 1.902 3rd = 1.308 4th = 1.000 (Direct Drive) 5th = 0.759 (Over Drive) All S14 SR20DET's 1st = 3.321 2nd= 1.902 3rd = 1.308 4th = 1.000 (Direct Drive) 5th = 0.838 (Over Drive) All JDM CA18DET's 1st = 3.321 2nd= 1.902 3rd = 1.308 4th = 1.000 (Direct Drive) 5th = 0.838 (Over Drive) All Euro CA18DET's 1st = 3.592 2nd= 2.057 3rd = 1.361 4th = 1.000 (Direct Drive) 5th = 0.821 (Over Drive) KA24 4WD Trucks (Hardbody's/Frontiers) 1st = 3.985 2nd = 2.246 3rd = 1.415 4th = 1.000 (Direct Drive) 5th = 0.821 (Over Drive) KA24 2WD Trucks (Hardbody's/Frontiers) - 1997 1st = 3.985 2nd = 2.246 3rd = 1.415 4th = 1.000 (Direct Drive) 5th = 0.838 (Over Drive) |
What rally car does he wanna build? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
