Hydraulic throwout bearing (Ford T5, behind Volvo)
Posted by Magnum TE
Magnum TE
Toby Eidelman
'92 Volvo 940T (tarmac dweller)
December 03, 2012 09:27PM
I'm looking to do a hydraulic TOB for my Ford T5. The KEP stage3 pressure plate crumpled my clutch fork like a paper cup and I don't really want to spend hours trying to strengthen it.
What Hydro TOB should I look for John?
I'm using the Volvo master, which I believe is 3/4" bore (need to double check that).
The Flywheel is a Sooooper bitchin steel unit with .970" standoffs. Kennedy told me that I need at least .250" finger movement to release completely and no more than .400" movement without the risk of dmaging the PP housing.
I'll be getting the required dementions this weekend.
http://www.ramclutches.com/tech%20revamp%20910/RAM%20Hy3.jpg
It looks like RAM clutches has the most inexpensive unit. Is there a better one?
(yes the trans is back out of my car again)
I like to play with cars, it's very inappropriate.
Edited 1 time(s). Last edit at 12/03/2012 09:27PM by Magnum TE.
Robert Culbertson
Out of this dumpster fire
Re: Hydraulic throwout bearing (Ford T5, behind Volvo)
December 03, 2012 11:27PM
I grabbed one for my f250 from rockauto, looks like they're at $65 now. I have heard somewhere (here maybe) that the aftermarket ones from summit/jegs/speedway can be garbage and leak crazy amounts.
And on second thought, they probably aren't the same since the f250 uses a different trans... so nevermind.
Edited 1 time(s). Last edit at 12/04/2012 12:19AM by Robert Culbertson.
Magnum TE
Toby Eidelman
December 04, 2012 04:13PM
Yeah I was hoping someone had a tip on an OEM hydro release that would work with the T5. I don't like paying +200$ for the setup but willing if it's going to work properly.
Robert Culbertson
December 04, 2012 06:53PM
From looking at pictures and from what I can remember, the ford trucks use a Mazda 5spd that uses a really long slave/throwout bearing combo. The T5 looks like it doesn't have nearly enough room to fit the slave. It might be worth it to take the trans down to autozone/napa and physically see if they slave will fit. 1 hr of time to possible save $150...
December 04, 2012 07:01PM
88 ThunderChicken Turbo Coupe was hydraulic clutch.
December 05, 2012 07:57AM
External slave cylinder, though.
Me, I'd just weld some beef metal to the fork. Don't forget to reinforce the pivot, too.
Magnum TE
Toby Eidelman
December 05, 2012 09:00AM
I'm going to try to hammer the fork back into shape and add some material. It's pretty twisted up so if I need to source a new fork (75$) just to start over and maybe make it strong enough for the pressure plate -I'd rather go with a Hydro TOB and not mess with the fork.
I did reenforce my pivot point pretty well.
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5%20Swap/IMG_0628.jpg
The fab guy doing the install for me just didn't continue the beef when it came to the fork.
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5%20Swap/IMG_0623.jpg if you zoom in on the fork part you can see that half the structure was removed to fit the larger ford TOB. I should have known better to run it without adding structural support.
I was pretty rushed when I did this last motor swap (blew a hole in a piston). I got a replacement engine 70hrs before race day, and I changed everything from the radiator back to the driveline. I finished at 4:45am with the driver's meeting at 7am, so some details were lost.
Edited 1 time(s). Last edit at 12/05/2012 09:01AM by Magnum TE.
ryanfay
guess
1983 volvo 242tic
December 09, 2012 11:25PM
I was dorking out in the fairyfield picknpull and found that the camaro gen 4 v6ers have a hydraulic throw out bearing that bolts to the input shaft bearing retainer ala the mcleod. The input shafts are the same as the ford mustakes, the as are the engagement points, the range of motion etc. Who knows how they fit in an adapter plate and bell housing since I dont have either now.
Magnum TE
Toby Eidelman
ryanfay
guess
1983 volvo 242tic
December 11, 2012 12:04AM
There are two ways to clock it, straight down, or out the cutout for the fork. The fitting is kinda tweeky and might be easiest (and more secure) to run a pipe tap. I wish the bleeder had a barb on the end so you could then hook up a hose and let her bleed without making a mess in the bellhousing.
December 11, 2012 06:42AM
I didn't realize you'd painted yourself into an adaptation corner like that.
Make extra sure that the Camaro throwout will retract enough. The 4th-gen Camaro T5 had a 3/4" longer input than the earlier boxes, and a deeper bellhousing to match. Why? Why not? IIRC it was also Ford bolt pattern, too, for extra fun. Crap ratios, because they were only ever used in the V6 models since the V8s were all 4L60 or T56.
Edited 1 time(s). Last edit at 12/11/2012 06:45AM by Pete.
Robert Culbertson
December 11, 2012 12:35PM
ryanfay
There are two ways to clock it, straight down, or out the cutout for the fork. The fitting is kinda tweeky and might be easiest (and more secure) to run a pipe tap. I wish the bleeder had a barb on the end so you could then hook up a hose and let her bleed without making a mess in the bellhousing.[/quote
I just tapped the bleeder tube for a standard brake bleeding nipple. It allows me to use a vacuum bleed tool, and it gets it out of the bell housing.
Also, that GM hydro-bearing looks surprisingly like the Ford ones.
ryanfay
guess
1983 volvo 242tic
December 11, 2012 05:16PM
Its shown in the pic mounted to a ford mustang t5. Im not set on using it, only Id like to.
I found it in the yard, and paid a whopping $8 for it. You tell them its a throw out bearing and dont ask if its mechanical or hydraulic.
Didnt mean to threadjack but I thought Id post it here as it might be a viable option.
Magnum TE
Toby Eidelman
December 11, 2012 05:47PM
Ryan, no thread jack -that's totally on topic.
I kinda thread jacked myself when I decided to try mending my fork.
So back on topic:
1996 - 2002 CHEVROLET CAMARO 3.8L V6 : Transmission-Manual : Clutch Slave Cylinder DORMAN Part # CS360058
CHEVROLET BLAZER (1996 - 2004)
CHEVROLET C1500 PICKUP (1996 - 1999)
CHEVROLET C1500 SUBURBAN (1996 - 1999)
CHEVROLET C2500 PICKUP (1996 - 2000)
CHEVROLET C2500 SUBURBAN (1996 - 1999)
CHEVROLET C3500 PICKUP (1996 - 2002)
CHEVROLET CAMARO (1996 - 2002)
CHEVROLET COLORADO (2004 - 2007)
CHEVROLET K1500 PICKUP (1996 - 1999)
CHEVROLET K1500 SUBURBAN (1996 - 1999)
CHEVROLET K2500 PICKUP (1996 - 2000)
CHEVROLET K2500 SUBURBAN (1996 - 1999)
CHEVROLET K3500 PICKUP (1996 - 2000)
CHEVROLET P30 (1996 - 1999)
CHEVROLET S10 PICKUP (1996 - 2004)
CHEVROLET SILVERADO 1500 (1999 - 2000)
CHEVROLET SILVERADO 2500 (1999 - 2000)
GMC C1500 PICKUP (1996 - 1999)
GMC C1500 SUBURBAN (1996 - 1999)
GMC C2500 PICKUP (1996 - 2000)
GMC C2500 SUBURBAN (1996 - 1999)
GMC C3500 (1996 - 2002)
GMC CANYON (2004 - 2007)
GMC JIMMY (1996 - 2004)
GMC K1500 PICKUP (1996 - 1999)
GMC K1500 SUBURBAN (1996 - 1999)
GMC K2500 PICKUP (1996 - 2000)
GMC K2500 SUBURBAN (1996 - 1999)
GMC K3500 (1996 - 2000)
GMC P3500 (1996 - 1999)
GMC SIERRA 1500 (1999 - 2000)
GMC SIERRA 2500 (1999 - 2000)
GMC SONOMA (1996 - 2004)
ISUZU HOMBRE (1996 - 2000)
PONTIAC FIREBIRD (1996 - 2002)
http://www.rockauto.com/getimage/getimage.php?imagekey=966903&imageurl=http%3A//www.rockauto.com/info/RB/CS360058-007.jpg
70$ on Rockauto
If I fold this fork again I'll try it out.
Edited 1 time(s). Last edit at 12/11/2012 05:48PM by Magnum TE.
modernbeat
Jason McDaniel
December 11, 2012 05:54PM
I've used the Jeep hydraulic throwout bearing on a T5 before. And it was all adapted to a '51 Ford flathead V8.
Jason McDaniel
