Volvo 240 Rally build
Posted by Eric Ewert
Re: Volvo 240 Rally build
May 22, 2013 09:21AM
BobOfTheFuture
You know, I came here to try to glean some helpful info and inspiration from a fellow 240ist who is deciding to make the big mistake leap.
And this is what I get...
Well, it was going good for a little while tongue sticking out smiley
Well it's a shame cause the guy can get good information to fit whatever budget he decides on but some person has to poke his ugny snout into every single thread and coimment at excessive length on things which are totally ancilliary to what the guy is needing..
The word is PRESUMPTUOUS....since he believes he knows everything he presumes the guy cannot himself filter the good information about building a good solid car and also take the other information and use that to position his buil;d in the context of the changes previously announced and the confusion and anger those changes have wrought..
And its further a shame nobody can get this one guy to shut the fuck up about shit he has amply demonstrated he has no fucking clue at all about...and that nobody assists in telling the guy to shut up and stick to the area he alleges he knows about.
May 22, 2013 10:08AM
John, no need to talk about yourself in the third person like that. :-)
Ok, maybe I should chill out a bit and just let you go on your misinformed rants that are done solely to make you feel like some folk hero but when you actively misrepresent current, or past, situations and when you use loaded language to suggest things that simply aren't true it gets under my skin.
It's a shame, really, because for the last couple of weeks we've been playing well together.
May 22, 2013 10:15AM
Morison, you must learn that you don't have to CORRECT (in your narrow, provincial, limited viewpoint) every single insignificant , throw away comment...
YOU are not the fount of the SOLE legitimate viewpoint ---indeed anybody with a rudimentary ability to read can see that wheat the adice and complaint is is that very easy flexible options have been thrown into a state of confusion by techincal incompetents..
Try sticking to what you have convinced some people you're so good at: PROMOTION and publicity..
THAT is what you do, so comment on THAT, not the point of view of others...
Creech
Scott Creech
Audi 90 Quattro (WIP)
May 22, 2013 02:46PM
So.... how 'bout them Volvo 240's, eh?
Wondermilious cars, ain't they!
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
BobOfTheFuture
Rob
None, anymore.
May 23, 2013 12:24AM
Creech
Indeed. I appreciate them in white!
Enablers, All of you.
Dobmaster
Alain Lavoie
93 STI Wagon
May 23, 2013 06:36AM
BobOfTheFuture
Creech
I like when they have speed holes in the hood.
May 24, 2013 01:21AM
this thread is so disapoint, it makes me want to cut my penis off and throw it off a cliff.
(look out below!)
darkknight9
Kirk Coughlin
Dreaming of escorts and xrats
May 24, 2013 05:48PM
John.
You are aware that CARS has struck another committee to take a fresh look at the 2wd classes aren't you?
Kirk Coughlin
May 24, 2013 06:22PM
(look out below!)
<object width="480" height="360"><param name="movie" value="
?hl=en_US&amp;version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param>
BobOfTheFuture
Rob
None, anymore.
May 26, 2013 12:08AM
Eric Ewert
Eric Ewert
volvo 240
June 24, 2013 11:57PM
Well I am finally done school for the year and have started working on this car. Started building some patch panels for the rust and this just occurred to me... pin hole jack stand mounts. I am currently cutting out rust in the rocker panels that is in the exact location where these should go... problem is I have no idea how to properly design the mount that you fit to the car. I've looked at a few previous threads but they seemed to be all about the stand itself instead of the pin holes. Could some one help/ point me to some instructions?
darkknight9
Kirk Coughlin
June 25, 2013 12:33AM
http://www.rallyanarchy.com/phorum/read.php?5,81530,81536
http://www.rallyanarchy.com/phorum/read.php?5,62095
http://www.rallyanarchy.com/phorum/read.php?5,27901,28186
HTH
Kirk Coughlin
Tree18is
Daniel Serna
BMW 318i
July 25, 2013 02:55AM
maybe while your patching sheetmetal I know those cars have big pig cheeks in the back. Possibly bob the rear end up to get some ground clearance.
Eric Ewert
Eric Ewert
volvo 240
September 07, 2013 12:13AM
Well finally got a small update... and a million more questions of course.
Interior is stripped minus door panels.
Started removing sound deadening.
Cut out rusty rear rocker panels. Actually fabricated a patch but then acquired free volvo factory replacement panels for the rear rockers. You can guess which im using.
Fixed leaky exhaust manifold gasket.
Fixed rear tale lights, contacts were just a bit corroded (thankfully)
Along with the free rocker patch panels I got a ton of nearly free volvo goodies, I will post a photo of these items later.
open | download - pic 2.jpg (161.7 KB)
open | download - pic 1.jpg (144.9 KB)
Eric Ewert
Eric Ewert
volvo 240
September 07, 2013 12:19AM
Interior shots... and the questions begin.
I need to fabricate the seat mounts. what is the general thought on this for 240's? Do people cut out the "bulkhead" that the seats sit on for a lack of better words. The first pic is looking right at what I am referring to. The thing with the holes in it and the heater routing for the rear passengers feet... hopefully this makes sense! confused smiley
The next detail... should I cut out the piece of sheet metal that separates the trunk from the rest of the interior or is it to be used for something? Second photo should make it pretty clear what im talking about.
open | download - pic 3.jpg (208.3 KB)
open | download - pic 4.jpg (145.2 KB)
