Volvo 240 Rally build
Posted by Eric Ewert
coryg57
Cory Grunwald
Re: Volvo 240 Rally build
March 07, 2014 10:26AM
Did Dave Clark build your tank shell too? I'm going to need to buy one of those at some point.
Project328is
Arno Guerin
Volvo 242
March 07, 2014 10:29AM
Yeap… he has the skid plate ready to be put on… this is going to be a tank or a brick!
Arno
"Sideways get you there Faster"
Eric Ewert
Eric Ewert
volvo 240
March 07, 2014 01:03PM
Whew, took grants suggestion and spun the mounts around. You were right, much thanks for pointing that out.
Anyway dropped the seat down a couple inches and now im a ok for room, and I wanted to drill a couple holes in these mounts I could drop it down further.
Heres a few photos to give a comparison from before, also one to show head room with a moto helmet on.
open | download - P1030949.JPG (28.8 KB)
open | download - P1030951.JPG (47.1 KB)
open | download - P1030952.JPG (43 KB)
BobOfTheFuture
Rob
None, anymore.
March 07, 2014 11:46PM
Eric Ewert
Heres a few photos
The rear seat bar, Would that interfere with a sill bar if you added one? Or would those be higher up?
Enablers, All of you.
March 07, 2014 11:50PM
BobOfTheFuture
Eric Ewert
Heres a few photos
Sill bar is usually right on top of the sill or close as you can weld 100%
Eric Ewert
Eric Ewert
volvo 240
March 08, 2014 01:35AM
I have sill bars, they are cut and fitted I just took them out for the ease of building the seat mounts. Zero interference. Well at least where I positioned my sill bars. You will be able to see soon enough.
Edited 1 time(s). Last edit at 03/08/2014 01:35AM by Eric Ewert.
sidewaez
Blake Lind
orange AE86
March 08, 2014 01:39AM
That looks much better, and yeah the sill bar should be up on top of the sill, I bent it out a bit and stitch welded it to the pinch weld at the bottom of the door opening.
March 08, 2014 09:48PM
Drill away on the seat mounts, no reason not to. I run mounts that Derik Nelson made.
Robert Culbertson
Out of this dumpster fire
March 08, 2014 11:27PM
Robert, are you building a Volvo now too?
I have been using the IPD skid plate on the DD. Works well, decently cheap, and it for on perfectly the first time. It's not heavy enough for all out rally duty, but it could be easily reinforced. I can post up some pictures if you'd like.
March 11, 2014 10:51PM
I got a 91 240 for cheap.
March 11, 2014 11:14PM
Well.
Watcher gonna do with it?
Robert Culbertson
March 12, 2014 11:36AM
I know you got it for cheap. But what is the plan? Recce car, rally car (still want your golf?!), winter beater? I'll post up some pictures of the IPD skid plate for ya. It's $140 new, and they can be reinforced if you wanted a more robust/rally style skidplate.
I just got the old turbo Volvo out on the streets. Boost is so much fun in that car!
March 12, 2014 11:42AM
Robert Culbertson
What a horrible design.. "skid" plates are supposed to help protect the sump/erl pan by having nice angle to help slide over stuff, like rocks... that horrible thing presents a nice face to BASH RIGHT INTO things... Brilliant!
(ever seen anything like that on a real rally car?)
Din't stink so.
March 13, 2014 06:10PM
Robert Culbertson
Main problem with these pans is they don't cover the sump! Just made to replace the plastic splash guard...
Robert Culbertson
March 13, 2014 07:25PM
Yes yes I know. Not the best skid plate for all out rally use. I was suggesting that Robert could use it (or a reinforced one) for recce duty in his ovlov. I am not advocating using this for a rally skidplate. I used the term "rally style" for a reason. It's like most things "rally", well I guess it should have a Subaru logo on it somewhere for that.
Though you could probably hack it enough to make it work...
