FOX MUSTANG
Posted by tdrrally
mellow65
Oliver Klozoff
Nada
Re: FOX MUSTANG
August 09, 2014 01:59PM
tdrrally
at last i got a chance to drive the mustang last night.
the steeda 5 link rear suspension and T2R are money well spent, thank you to whoever bought that bit of kit!
now i get to spend some time going over the whole car
didn't that kit not allow for full exhaust? and it needed something like turn downs or side exhaust
tdrrally
edward mucklow
Re: FOX MUSTANG
August 10, 2014 07:20AM
it has been done, with a bit of work
it has turndowns on it now and they suck!
Edited 1 time(s). Last edit at 08/10/2014 07:24AM by tdrrally.
Undertaker
Jay
none :(
Re: FOX MUSTANG
September 13, 2014 09:35PM
Looking forward to this. Any new updates?
Re: FOX MUSTANG
September 14, 2014 03:22PM
Wow, that is tighter than an ugly..well anyway not much room. One thing that can be done on some cars is to cut the stock floor to allow room for exhaust then weld boxes over it, similar to rear shock or control arms.
tdrrally
edward mucklow
Re: FOX MUSTANG
September 15, 2014 10:57AM
i was thinking about using 180deg mufflers and exit the exhaust in front of the rear wheels
Re: FOX MUSTANG
September 15, 2014 07:59PM
Out the side , especially that far forward is not a good deal. Ground clearance gets pretty sketchy. Do you have room to drop under the axle aka Volvo, MGB or Datsun? We used to do that with Camaros back in the day. While it does hang down maybe as much as side dumps, it isn't perpendicular to all objects. Years ago GM released data indicating the actual horsepower difference between a '69 Camaro and '69 Corvette was about 30 hp I think. Every 90* bend equals 15 ft of straight pipe for restriction. Camaro was a single muffler sideways behind the axle so 90 up 160ish over and 90 in, 90 out vs nearly straight in and out on the 'Vette.
Robert Culbertson
Out of this dumpster fire
Re: FOX MUSTANG
September 15, 2014 09:39PM
The fox body does not have a lot of room to run a side exit, or rally much room for anything. Heading straight under the axle should be fine, you can even armor the tubes with some angle iron on the bottom to give it a fighting chance. Maybe gontonsome oval tubing under the axle ?
tdrrally
edward mucklow
Re: FOX MUSTANG
September 16, 2014 05:35AM
how about a set of 180 deg muffler that exit up then turn the pipe 90 degs then exit the car in the quarter panel behind the doors?drinking smiley
Robert Culbertson
Re: FOX MUSTANG
September 16, 2014 11:24AM
Why not run glass packs and then forget the 180° muffler?
You could cut the floors and move the exhaust up, and that would help in the side exit exhaust.
But that's a lot of work. I'm all for stacks out the hood.
Re: FOX MUSTANG
September 16, 2014 11:34AM
mellow65
Oliver Klozoff
Nada
Re: FOX MUSTANG
September 16, 2014 11:44AM
Merica!!!!!!!!
tdrrally
edward mucklow
Re: FOX MUSTANG
September 16, 2014 12:54PM
i am thinking something more like this
Re: FOX MUSTANG
September 16, 2014 10:21PM
...a Fox in Australia? Why dey do dat?
Re: FOX MUSTANG
September 17, 2014 12:52AM
tdrrally
Crazy bastids, or are they? Don't think there's going to be many grapefruit sized rocks bashing the thing shut...
Any rocks where you are? If not don't worry.
tdrrally
edward mucklow
Re: FOX MUSTANG
September 17, 2014 07:48AM
how about over the roof saab 96 style
