tdrrally
edward mucklow
Re: FOX MUSTANG
September 18, 2014 12:10PM
if i don't like the mustang i will build a ranger or something and sell the mustang to road racer
or just go learn to fly (probably cheaper any way)
mellow65
Oliver Klozoff
Nada
Re: FOX MUSTANG
September 18, 2014 12:34PM
tdrrally
I like the idea of the ranger. I like what the v8 rally ranger guy from out east is doing with his. It doesn't get much more simple than his approach to all this rally stuff.
tdrrally
edward mucklow
Re: FOX MUSTANG
September 18, 2014 02:41PM
simple is why i got a fox mustang
mellow65
Oliver Klozoff
Nada
Re: FOX MUSTANG
September 18, 2014 05:32PM
tdrrally
Ok honestly, that's even more true. Being able to buy all your parts off of a shelf, what's that like? smiling smiley
tdrrally
edward mucklow
Re: FOX MUSTANG
September 18, 2014 06:16PM
i love it!!!!thumbs up smiley
Robert Culbertson
Out of this dumpster fire
Re: FOX MUSTANG
September 22, 2014 10:19AM
Here's one solution to gain some space if running the exhaust over the axle. It's just a bend that is cut down the center with a section of flat bar welded in.
If your up to the task it's not too hard. The asking price for the bends it a bit extreme. But hey, oval tubing is becoming cheaper and easier to find!
http://www.spintechmufflers.com/oval-tubing/oval-elbows/vertical-oval-elbows/cat_46.html
tdrrally
edward mucklow
Re: FOX MUSTANG
September 22, 2014 10:35AM
its a thought, thank you for the information
tdrrally
edward mucklow
Re: FOX MUSTANG
September 23, 2014 08:45AM
battery placement is the big question this day
1) i'm thinking of putting the battery as far back as possible, behind the rear axle
2) or put the battery where the back seat was, fairly low and just in front of the axle
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: FOX MUSTANG
September 23, 2014 10:50AM
Weight distribution is not going to win a rally, at least not in the US. I would put it somewhere that it is easy to get to, easy to jump, and safe. Is the stock location not use able? The costs of moving the battery into the passenger compartment are possibly greater than just buying a light weight small form factor battery and connecting it to the factory cables.
tdrrally
edward mucklow
Re: FOX MUSTANG
September 23, 2014 10:59AM
stock location is not an option
i have most every thing it will take to relocate the battery
i have installed them in the rear seat area with good result in the past
and the very rear is already very tight with tools, tyres, ect
Re: FOX MUSTANG
September 23, 2014 05:22PM
Accessible and well mounted. The red civic roll I posted the optima battery was never found. Codriver saw it fly out where the sunroof panel had been.
tdrrally
edward mucklow
Re: FOX MUSTANG
September 23, 2014 06:03PM
yikes!
i am thinking real battery box bolted through floor with large washers on both side
tdrrally
edward mucklow
Re: FOX MUSTANG
September 24, 2014 06:12AM
thinking something like this
http://www.summitracing.com/parts/sum-g1230/overview/
or this
http://www.bajatested.com/Baja-Tested-Optima-Battery-Box.html
Re: FOX MUSTANG
September 24, 2014 09:41AM
Cute.
Baw-jaw testes...odd they din't say it passed...
Whatever. I was going to suggest this but then i realised my error.
don't bother looking at anything from AA Mfg---
like this battery box:
AA-111-A 11" BATTERY BOX PREWELED
$28.60
Buy 10 for $22.95 each
AA-111-KC 11" BOLT ON BATTERY BOX KIT
$30.28
AA-111-B 9" BATTERY BOX PREWELDED
$26.40
Buy 10 for $21.65 each
AAA-111-KA 11" BATTERY BOX KIT WITH 3/8" BOLTS
$24.20
Buy 10 for $19.84 each
AA-111-KB 9" BATTERY BOX KIT WITH 3/8" BOLTS
$23.10
Remember more cost is ALWAYS better no matter what...always look for the most expensibve thing, it means its "Quality"..
It's only money..
SPEND SPEND SPEND, it's your right. It's your duty!
BOBODY can tell you how to spend, but by god spending is the answer.
And don't ever think what a poor use of the word "quality" is when used like that.
Re: FOX MUSTANG
September 24, 2014 09:57AM
Link John?
