badcamber
Alan Edwards
2000 Dodge Neon
Harness attachment questions
April 21, 2014 07:19PM
Hey everyone,
I have been searching through all the posts and I have not been able to find what I am looking for. I am getting ready to install the harnesses in the car and it does not look like I am able to use the OEM mounting locations, due to both the angle and the fact they would be rubbing against the roll cage. What is the preferred mounting method. Can i mount it to the roll cage or does it have to be mounted to the body.
Re: Harness attachment questions
April 21, 2014 07:53PM
Shoulders to cage, lap and subs through floor with reinforcement plates. Suggest strongly eyes and clips.
badcamber
Alan Edwards
2000 Dodge Neon
April 21, 2014 08:28PM
Is there any specific requirement for the reinforcement place Ex. play must be so many square inches? Recommended size. I know the rules say it must be able to handle a load of 3000 lbs..
April 21, 2014 08:51PM
FIA rules specify plate size, something like 40 cm^2 and at least 3 mm thick (1/8"winking smiley.
I usually do a 2.5" square as I have lots of 2.5" strapping usually.
Edited 1 time(s). Last edit at 04/21/2014 08:52PM by NoCoast.
Robert Culbertson
Out of this dumpster fire
April 21, 2014 10:10PM
I thought it was 16 sq.in. For the harness points.
Definitely 1/8in thickness though.
badcamber
Alan Edwards
2000 Dodge Neon
April 22, 2014 10:41AM
Thank you guys, so if I were to create a mounting point where the harness is at in the picture that should work?
Edited 2 time(s). Last edit at 04/22/2014 10:46AM by badcamber.
open | download - 20140418_204641.jpg (38.4 KB)
czwalga
steve czwalga
95 awd celica
April 22, 2014 11:03AM
badcamber
I'd just weld 1/8" on to the floor. Then another 1/8" perpendicular with a hole welded to that. Right where you have the harness now
April 22, 2014 11:05AM
Steve - Did you just make your own L bar (or angle iron as we used to call it).
czwalga
steve czwalga
95 awd celica
April 22, 2014 11:16AM
More like a inverse T. The 1/8" on the floor is more spread out, the piece with the mounting hole is probably only 2x2.5" or something. Piece on the floor might be 3x3.
______________________
|********** _ ***********|
|******** /.......\ *********| 1/8" Plate with mounting hole.
|******** \.._ ../ *********|
|***********************| weld
------------------------------------------ 1/8" floor
On my subaru, I have the seats mounted to 1.5" bars going from the sill to the tunnel, then mounts welded off of the bars so nothing is attached to the floor. That example doesn't really help in Alan's case here.
Edited 3 time(s). Last edit at 04/22/2014 11:21AM by czwalga.
April 22, 2014 12:54PM
I would suggest simply using backing plates as designed, like a giant washer, and not welding them. Too much chance of weakening the floorpan at the welds.
czwalga
steve czwalga
95 awd celica
April 22, 2014 02:02PM
What do you mean by backing plates? A lot of cages are welded in similar fashion to the floor. except with a 36 sq. inch requirement.
April 22, 2014 05:46PM
We've always built cages with mounts on multiple surfaces, e.g., horizontal and vertical and mounted to frame/unibody, not just floor. Seen too many autopowers pop through the floor.
April 22, 2014 08:48PM
Now that I see a picture I would follow Steve's suggestion and weld a plate on the floor and a perpendicular plate off that for the belt to actually mount on. I personally don't like to see anything bolted thru a floor just for gravel and impact damage. Yes you can teflon cover the whole underside and protect those precious thread but shit happens and teflon sheets get torn off and so on.
badcamber
Alan Edwards
2000 Dodge Neon
April 22, 2014 09:23PM
Thanks Gene,
I know pictures can make all the difference. You know if I ever make it out your way I think I am going to owe you a few beers for all the help
April 22, 2014 11:00PM
badcamber
Thanks Gene,
No beers young grasshoppa...Black Velvet is the scrutineers poison of choice grinning smiley
