Buy, Sell & Trade
cris519
Christian Arboleda
Suzuki Swift Gti
Suzuki Swift Gti - G2 Rally Car
September 28, 2015 11:40AM
Hey Guys,
I'm putting my 1992 Suzuki Swift GTI rally car up for sale.
Description: Turn key rally car. Suzuki Swfit GTI Fully Prepared
The car is top notch condition, No Expense spared on this build.
Shell:
• NASA Logbooked
• Lexan windows – Plastic 4 Performance window kit
5 piece fully thermoformed polycarbonate window kit
Each window is marked to meet MSA, FIA & ABG regulations
• Wide fiber glass fender flairs done all around
• Cup mirrors
• Fiberglass Light Pod
Engine:
• G13B 1324cc built by Amazon Racing
• Forged High compression pistons 76mm design for high lift camshafts.
• Haltech Platinum Sprint 500 ECU and loom, Coils
• Custom quad throttle bodies with ITG filter
• Highly modified cyl head with + 1mm Ferrea valves. Full Race Titanium & Special
Alloy Valve Train Kit. Titanium Retainers, single reinforced race valve springs
(for better harmonic balancing), valve locks and seat locators. Solid lifters
• Forged Connecting Rods with ARP bolts
• Lighten and Knifed Edged Stock Crankshaft
• Race Main bearings
• Race Rod bearings
• Ultra-light weight 4:1 Header using Stainless Steel T304 1 3/4” dia
• High profile Cams with Aluminum Adjustable Cam Gear
• Aluminum Flywheel
• Aluminum Underdrive Single Pulley
• ARP Cylinder Head Studs
• ARP Main Studs Kit
• High Performance Head Gasket
• Modified dizzy for ECU
• Adjustable Fuel press regulator
• New high flow injectors
• Walbro high volume in tank fuel pump. Extra fuel MSD fuel pump outside.
• All hard fuel lines ran inside.
• Polyurethane filled engine mounts
Gearbox:
• 5 Speed straight cut dog box
• LSD Differential
• Race Clutch Masters
• Motorsport Aluminium Shifter with cables
Suspension:
• 40 mm inverted Bilstein Coilovers all around. Long Travel
• Modified rear top mount and towers to fit rear coilovers.
• Rear toe bar with uniballs
• OMP Strut Brace
Brakes:
• GTI front/rear calipers with drilled & slotted rotors
• Portiflied brake pads
• 45 Degree Hydraulic Handbrake with Willwood master cylinder
& Proportioning Valve, Lever Style.
• All braided brake lines.
Wheels / Tires:
• 5 New Braid 14” Rims
• 175/70 14 Dmack used tires
• ARP Wheel Studs
• 20mm aluminium spacers
Safety:
• Monaco Cobra Seats.
• First Aid / Two extinguishers all present.
Interior:
• Custom dash & switch box on the floor.
• Phantom Autometer 5" Tach, SHIFT-LITE
• Phantom Autometer gauges ( fuel, battery, oil and water)
• Innovate Wideband Air/Fuel Ratio Gauge.
Spare package:
Brand new axles, head, cams, control arms, etc.
I am asking $10,200 obo. The car is located in Irvine, California.
Feel free to PM me with serious interest.
Thanks,
Christian
Re: Suzuki Swift Gti - G2 Rally Car
September 28, 2015 12:05PM
So nice car! Chris why you selling it? Its ready and sooo sooo well done.
cris519
Christian Arboleda
Suzuki Swift Gti
September 28, 2015 12:25PM
Hi John,
Thanks! I have another project in mind so I need funds to finish it. I have a baby now so I am allowed to have just one rally car at home eye rolling smiley. By the way thanks for the suspension it works really well.
Christian
September 28, 2015 01:53PM
cris519
Hi John,
Christian
What is the other project? You can whisper so nobody will know.
And how old is the baby? Girl? boy?
Where's the photos? I am a complete silly guy about babies.....and I am so lucky with my 2...now 10 and 8...
urr
Andrew Sutherland
Subaru, EVO, Honda, Husky
urr
September 29, 2015 04:09AM
Great looking car...well done!
cris519
Christian Arboleda
Suzuki Swift Gti
September 29, 2015 03:14PM
He is 16 month old's. I will let you know soon about the other project.
cris519
Christian Arboleda
Suzuki Swift Gti
Thanks!
BobOfTheFuture
Rob
None, anymore.
October 01, 2015 10:49AM
Old belts for quick-release tire tie down?! Brilliant!
Enablers, All of you.
October 01, 2015 03:09PM
BobOfTheFuture
They aren't old belts. Sabelt only started making the Hans style belt in 2014.
Also, I made that last bit up. I do agree that that is a great idea.
October 01, 2015 04:18PM
Some people have been using old car seatbelts since time began...come in all sorts of colors.
DTDB
Dave Brown
To Be Purchased
October 07, 2015 06:47PM
What type of fuel does it use? What is the approximate weight? And what is the approximate power?
cris519
Christian Arboleda
Suzuki Swift Gti
October 08, 2015 10:52AM
The car is running VP-101. The weight of the car is 685kg and the approximate power is 145+ hp.
DTDB
Dave Brown
To Be Purchased
October 10, 2015 09:24AM
This car is awesome! I'm afraid it's too much car for my first rally car. Someone will tear it up in this car though.
B85
Randy Wefel
98 Forester
B85
October 12, 2015 04:06PM
Great looking car.
"Oh, RALLY !
William Marenich
William Marenich
91' VW Golf GTI
October 22, 2015 02:52PM
Great looking car, good luck with the sale!
