kentmdavis Kent Davis Professional Moderator Location: Charlotte, NC Join Date: 11/30/2006 Age: Possibly Wise Posts: 16 Rally Car: 1990 Eclipse GSX fwd-only |
First Generation Mitsubishi Eclipse GSX, currently configured to run FWD stage rally. Car runs great, needs a new home to get back into competition where it belongs! Rally Car, trailer, and extras priced to sell at $5000 704-608-4185 or kentmdavis@gmail.com Description: Roll cage tied to front and rear suspension points Heavy Duty Aluminum Front Skid plate Pop-up Headlights converted to non-pop-up HID for weight reduction Custom Roof Vent Sparco pedal covers Sparco Seats 5 point harnesses (expired dates) Momo steering wheel All AC components removed (stock heat/defrost retained) Battery (Optima Red Top) relocated to center of car Spare tire and jack mounts Bumper mounted light bar 2-Hella Rally 1000 HID and 2 Eagle HID Turning Lights TerraPhone intercom and headsets Terra Trip 303+ rally computer Suspension: HotBits Rally Suspension Energy Suspension poly suspension bushings Custom adjustable strut towers Driveline: Forced Performance 18G Turbo HKS 264 Cams Kaaz Limited Slip Front Differential Aluminum Pulleys FRH Intake manifold with 75mm Throttle Body 95 Ported ceramic coated exhaust manifold 95 Ported ceramic coated turbo outlet Prothane Motor and transmission mounts MSD DIS-4 Ignition Custom 3 inch exhaust (turbo back) with high-flow cat Walbro 255lph fuel pump upgrade Spearco 120 Front Mount Intercooler Fluidyne aluminum racing radiator Driveline Shop Heavy Duty Front axle shafts Includes AWD driveline Brakes: DSM Large 2 pot front brakes Cryo brake rotors Porterfield Racing Pads Braided stainless steel brake lines Wheels and Tires: 4 - SSR Integral A2 Wheels with tarmac tires 11 – 15" alloy wheels with used rally tires Numerous spares Transport Trailer: 2 axle Trailer with loading ramps Large truck-bed mounted toolbox mounted Tire Rack mounted to carry 8 wheels/tires Load-Leveler Heavy-Duty Trailer Hitch Here are some embedded pics, as the RA download and resize bombs with /tmp out of space: Direct Links to the pics if the embedded don't work: https://drive.google.com/file/d/1BXzMdTQPGykrk02Yhh1mkzCOQvteEkLY/view?usp=sharing https://drive.google.com/file/d/1Jibiw3MbvJCWcuG5BJqo-Ji8Oapa964b/view?usp=sharing https://drive.google.com/file/d/1ERBhskmpw-hV5zK0txi1QAFE1Prq8XPJ/view?usp=sharing https://drive.google.com/file/d/12M2YmW59z36z5uYQrPm9f43BVllrLeqQ/view?usp=sharing https://drive.google.com/file/d/1suevcZ1BMy1tXTXXsjz8KjDa2z2c8SDl/view?usp=sharing Thanks for looking! Car has been sold. Thank you everyone for your interest! Edited 1 time(s). Last edit at 03/16/2018 09:19PM by kentmdavis. |
