Buy, Sell & Trade
Brantz/Hella/Terratrip/Sparco/Tilton/GForce/DemonRally VW
Posted by Tom B
June 22, 2008 11:35PM
Brantz International 2 'S' Pro Trip Meter $250
5 Hella Rallye 4000 Driving Lamps w/guards, 3 pencil, 2 cornering $80 each
Terratrip Terraphone Professional Intercom, w/two practice headsets $200
18" Avanti Map light $40
Sparco Sprint Racing seat $150 (some dirt, stains and small burns)
Tilton Quick adjust proportioning valve $60
FIA Cert-2012 Black G-force Racing 6-point Camlock Harnesses and sparco shoulder pads $200
Sprint car Window Net Set $40
Demon Rally Shark Fenders $100ea donation
Demon Rally numbered Doors $40ea donation
Rabbit Reinforced lower tie-bar, complete weld-in Skid plate assembly, and two matching skidplates W/brackets and mounting hardware $450
Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $80 each
Rabbit 16V Long tube exhaust header $100
Rear rabbit Euro bumper $40
Rabbit Bilstein Front Rally Struts/Springs $300 (1.1 rallies)
Rabbit Biltema Front Rally Struts/Springs/Bearings $225 (new)
Rabbit Bilstein Front HD Struts/Springs/Bearings $250 (new)
Rabbit Bilstein Rear HD Struts/spring assembly $125 (4 rallies)
Rabbit KYB Rear struts/spring assembly $50 (used, not rallied)
Rabbit Brand New (fresh ends) 100mm axle set $200
Rabbit New Short (fresh ends) 100mm axle $100
Rabbit Power Steering Rack, new complete tie rods $225
Rabbit Steering knuckles/bearings, $25ea
Rabbit 10.1" rotors $20/pr
Rabbit Fuel Pumps $50 ea
Rabbit Fuel Accumulator $20
Rabbit Fuel Tank $50
Rabbit nasty 2.25" exhaust with a bunch of metal welded to it $40
Rabbit small tail lamps $45/set
Rabbit rear Tail panel filler $50 (used to convert large tail lamp cars to small tails w/o body work)
Rabbit Solid Aluminum rear engine mount $100
Rabbit Front poly engine mounts $20ea
Rabbit rear beam $20 ea
Rabbit Carbon fiber look PVC Sintra Door panels $50
Rabbit driver's side flag mirror $20
Rabbit H4 Headlamps $50
Rabbit Heim shift linkage $75
Scirocco shifter box w/leaning handle$20
OBO winking smiley
mack73
Jason Wine
Re: Brantz/Hella/Terratrip/Sparco/Tilton/GForce/DemonRally VW
June 23, 2008 02:17PM
Tom the Brantz is mine !!!!!!!!!!!!!!!!
Oh and the Sprint car window nets and Avanti Map light.
-Jason
Edited 1 time(s). Last edit at 06/23/2008 02:21PM by mack73.
DR1665
Brian Driggs
Keyboard. Deal with it.
June 25, 2008 04:30PM
Those fenders would look siiiikkkk in someone's garage.
June 25, 2008 08:48PM
seriously, they'd be dope as garage art.
iRACECAR
Roy Farrell
A sullen Scirocco awaiting a transfusion of blood, sweat, tears, and heaping armfuls of non-existent money.
June 29, 2008 07:04PM
Why is it that whenever I'm profoundly broke, all the screaming deals from unfortunate events happen?
July 09, 2008 11:09AM
UPDATED LIST:
some images available upon request
Bunch of spare parts for sale here for BO:
Race Stuff:
2 Sparco six-point camlock racing harnesses Expired FIA Cert $250 ($300ea new) Looks like
Current FIA Cert-2011 Black G-Force Racing 6-point Camlock Harnesses and sparco shoulder pads $200 Looks like
Current FIA Cert-2011 Grey/Silver Willans 6 point Camlock Harnesses $350 ($300ea new) Looks like
Terratrip Terraphone Professional Intercom $75 ($100 NEW)
Garage Art/Help Us get back out again:
Demon Rally Shark Fenders $100ea donation Looks like
Rabbit Specific:
Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $75ea/$100pr Link
Rear rabbit Euro bumper $30 (driver's side scuffed)
Rabbit Bilstein Front Rally Struts/Springs $300 (1.1 rallies)Link
Rabbit Biltema Front Rally Struts/Springs/Bearings $225 (new)Link
Rabbit Bilstein Front HD Struts/Springs/Bearings $250 (new)Link
Rabbit Bilstein Rear HD Struts/spring assembly $125 (4 rallies)Link
Rabbit New Short Driver's Side (fresh CV's) 100mm axle $100
Rabbit 10.1" rotors $20/pr used
Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $40
Rabbit rear tail panel filler $50 (used to convert large tail lamp cars to small tails w/o body work)Link
Rabbit H4 Round Headlamps $50
Rabbit Heim shift linkage $70
Scirocco 16V exhaust manifolds $60 ea
Scirocco 16V stock downpipe and newer catalytic converter $45
Rabbit Non-AC Heater/Defroster box and heater core $20
Rabbit Rear Axle Beams $40
Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea
80 rabbit hood $20
80 Rabbit non-defroster hatch $20
83 GTI non-sunroof ROOF SKIN $40
77 Rabbit (lightweight) doors L & R $50 ea
Under the Hood:
Schrick 276 Cams, exhaust cam has very light keyway damage from a timing belt slip, was never an issue, just need to torque it down properly gears are pressed on already $450 (~$750+ new)
Rare Velocity 55mm 16v throttle body $300 ($400 new) Link
New 60 Amp Golf II 8v alternator $70
9A 020 8V GTi Transmission Used $180
2Y 020 16V GTi transmission Used $225
2.0L 16V 5K mile old cylinder Head Fresh Rebuild No cams (stock can be supplied and installed) $250
4 14" Snowflake Rally Wheels $50/set
more to come :screwy:
July 09, 2008 06:35PM
Possibly interested in the Willans belts (two right?) and terraphone. How long are the shoulder straps? I have an fia kit for a GC8 and the harness bar is more or less on the rear deck. Think wrapping the shoulders would cause an issue with the FIA cert??
July 10, 2008 01:09AM
yup, that'd be for two sets of belts, I'll check on the length and get back to you. Only have 1 professional terraphone unit left, no transit headsets.
Couldn't tell you about wrapping the shoulders affecting the FIA cert, never dealt with an FIA cage before..chat with a scrutineer to make sure.
July 10, 2008 07:30AM
Checking it with Willans.
July 10, 2008 11:30PM
Belts are sold...sorry.
Updated list:
Race Stuff:
1 Terratrip Terraphone Professional Intercom $75 ($100 NEW)
Damaged Demon Rally Shark Fenders $100ea donation Looks like (one SOLD, thanks Matt!)
Damaged Demon Rally numbered Doors $40ea donation
Rabbit Specific:
Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll)
Rabbit Fuel Accumulators $20 ea
Rabbit Fuel Tank $40
Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20
Rabbit custom Heim joint shift linkage $70
Scirocco shifter box w/rocco leaning handle $20 (works in a Rabbit, puts the shifter closer to you)
Rabbit Non-AC Heater/Defroster box and heater core $30
80 rabbit hood w/hood pin hold-downs $20
83 GTI non-sunroof ROOF SKIN $20
77 Rabbit (lightweight) doors L & R $40 ea
Under the Hood:
JohnLane
John Lane
The Fire Breathing Monster
July 12, 2008 12:28PM
Tom and Don I hope that you two are beavering away at your new project.
I want to see the two of you racing at Pomeroy in a few short months.
JohnLane
July 12, 2008 07:55PM
Pomeroy? it's a possibility, but we need to sell some more of this crap...Our VERY optomistic date is for DooWops 09, but I won't rule anything out right now.
mothra
Matt Smith
xr4ti
July 28, 2008 12:40PM
Did you sell of the driving lights yet?
Matt Smith
July 28, 2008 03:54PM
the lights were sold in the first 10 minutes...here is the latest list:
Race Stuff:
2 Sparco 70" H-style five-point camlock racing harnesses SFI Build date 5/2004 $250/pr ($600pr new) Looks like
1 Sparco 70" H-style shoulder harness (ONLY) for cam-lock 3' belt sets SFI Build date 10/2003 $40
4 Kumho R700 Rally tires 205/60/15 not a ton of tread depth left, but very little corner wear $75/all
Lengths of FIA Homologated rollbar padding both 1-14"-1-5/8" up to 2" $5/chunk
1 Rally Legal first aid kit $ 60
2 5# fire extinguishers $40
Rabbit Specific:
Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $75ea/$100pr 2 Sets left! Link
Rabbit KYB Rear struts/spring assembly $50 (used, not rallied on)
Aluminum dash $50 no gauges
Polyurethane rear transmission mount $20
Poly rear beam bushings $10
One power steering tie-rod end new $15
Rabbit used 10.1" rotors and Porterfield R4 pads $70
Rabbit Fuel Tank $20
Scirocco/rabbit 16V exhaust manifolds $60 ea
Scirocco/rabbit 16V stock downpipe and newer catalytic converter $45
Scirrocco/Rabbit 16V reinforced pedal cluster with sprung clutch return, 22mm master cylinder and 16v brake booster combo $75
Rabbit CIS K&N drop in filters $30ea
Scirocco 16v e-brake cables for rear discs $30
Scirocco 16V Cis-E wiring harness for a rabbit $50
80+ rabbit gas caps $10ea
Stock Rabbit A-arm set $40
VW Motorsport rabbit rear Transmission mount $40
factory vw rabbit radiators $20 ea used/working
custom 1/8" rabbit aluminum radiator shroud $20
rabbit overflow bottles $5ea
US Spec long tail lights great shape $50/set
other
4 Fluent warrior 195/60/14 Nearly new, almost 0 wear $100/set
MKII 9.4" hub set nearly new with race pads, lightly used rotors, Kelsey-Hayes Calipers and newer good ball joints, comes with 2 sets of Porterfield R-4S (race) pads used, $600 in parts, $150 takes it (hell the pads run $100/set alone)
16" ADR 6-spoke rims, all with light to moderate curb/scrapes, all fixable, worn tires (still hold air) rabbit/golf specific hub-centric spacers, will need 5mm spacers on the rear for proper fitment $250
New in Box 60 Amp Golf II 8v alternator $70
Audi 20V NA 5cyl bottom end $50
Fuba antenna and cables $20
CIS basic fuel injection setup $40
Golf II 42mm intake manifold $25
oil pan with turbo return line welded in $20
August 01, 2008 11:42AM
Tom,
I would like to buy some of your struts, wheels and 9.4 stuff. Can you give me a call at 425-766-6559.
Thanks, Robert.
