Buy, Sell & Trade
Re: Brantz/Hella/Terratrip/Sparco/Tilton/GForce/DemonRally VW
August 03, 2008 12:30PM
UPDATED LIST 8/3/08
some images available upon request
Bunch of spare parts for sale here for BO:
Race Stuff:
2 Sparco 70" H-style five-point camlock racing harnesses SFI Build date 5/2004 $250/pr ($600pr new) image
1 Sparco 70" H-style shoulder harness (ONLY) for cam-lock 3' belt sets SFI Build date 10/2003 $40 image
4 Kumho R700 Rally tires 205/60/15 not a ton of tread depth left, but very little corner wear $75/all image image image image image
Lengths of FIA Homologated rollbar padding both 1-14"-1-5/8" up to 2" $5/chunk
1 Rally Legal first aid kit $ 60
2 5# fire extinguishers $40
Rabbit Suspension/Braking:
Reinforced VW Rabbit A-Arms, new ball joints, poly bushings $75ea/$100pr 2 Sets left! Link
Rear rabbit Euro bumper $30 (Rally legal tow points attached, driver's side scuffed from roll)
Neuspeed rear rabbit swaybar (NLA) $150 ($300 NEW)
Polyurethane rear transmission mount $20
Poly rear torsion beam bushings $10
One power steering tie-rod end new $15
Rabbit New Short Driver's Side (fresh CV's) 100mm axle $100 image
Rabbit Power Steering Rack, new complete tie rods $225 image
Rabbit used 10.1" rotors and Porterfield R4 pads $70
Rabbit Front poly engine mounts $20ea
Rabbit rear beam $20 ea
Scirrocco/Rabbit 16V reinforced pedal cluster with sprung clutch return, 22mm master cylinder and 16v brake booster combo $75 image
Scirocco 16v e-brake cables for rear discs $30
Stock Rabbit A-arm set $40
VW Motorsport rabbit rear HD Transmission mount $40
Misc Rabbit Stuff:
Aluminum dash $50 no gauges image
Rabbit Fuel Pumps $50 ea
Rabbit Fuel Accumulators $20 ea
Rabbit Fuel Tank $20
Rabbit nasty 2.25" exhaust with a bunch of metal welded to it, dents $20
Rabbit Carbon fiber look PVC Sintra Door panels $50
Rabbit driver's side flag mirror $20
Rabbit H4 Round Headlamps $50
Scirocco/rabbit 16V exhaust manifolds $60 ea image
Scirocco/rabbit 16V stock downpipe and newer catalytic converter $45 image
Demon Rally Blue Modded (trimmed unprofessionally for a-arm damage) Early round headlamp fenders $30 ea
80 rabbit hood w/hood pin hold-downs $20
80 Rabbit non-defroster hatch $20
83 GTI non-sunroof ROOF SKIN $20
77 Rabbit (lightweight) doors L & R $40 ea
Scirocco 16V Cis-E wiring harness for a rabbit $50
factory vw rabbit remote reservoir radiators $20 ea used/working
custom 1/8" rabbit aluminum radiator shroud $20
rabbit overflow bottles $5ea
US Spec long tail lights great shape $50/set
other
4 Fluent warrior 195/60/14 Nearly new, almost 0 wear $100/set image image
16" ADR 6-spoke rims, all with light to moderate curb/scrapes, all fixable, worn tires (still hold air) rabbit/golf specific hub-centric spacers, will need 5mm spacers on the rear for proper fitment $250 image image image image
Golf/Jetta/Corrado Neuspeed swaybar, may be bent, one bad heim, $40
9A 020 8V GTi Transmission Used $180 image
5 14" Snowflake Rally Wheels $60/all image image
Audi 20V NA 5cyl bottom end $50
Fuba Radio antenna and cables $20
CIS basic fuel injection setup $40
Golf/Jetta II 42mm intake manifold $25
oil pan with turbo return line welded in $20
Golf/Jetta II brake booster and 20mm master cylinder $20 image
Edited 3 time(s). Last edit at 08/04/2008 12:42AM by Tom B.
