Buy, Sell & Trade
Round 2 JVAB steel flywheels for Volvo
September 28, 2011 05:57PM
Welcome to the asylum intinerant Turbobrickers---plus any rally-Volvo pervs
Here's the safe house for the info.
here's the list: ................................................Deposit sent
01. Patrick Helzer aka 700V............w 60-2..........................NO
02. Hallvard Buer aka RS1..w 60-2 and custom bolt circle...............NO
03. Eric Olsen aka Poik............w 60-2............................Jepp
04. Alex Morgan aka Lord Athlon ....w 60-2.......................NO
05. Alden Merchant aka WindowsBreakerG4....w/o 60-2................YES
06. Mattias Mellum aka Matti......w 60-2.......................Jovisst
07. Taliessin Penfound aka vertigosity..(2)..w 60-2......................NO
08. Taliessin Penfound.......................................................YES
09. Alex Nordenson aka Manimal......w 60-2..................................YES
10. Albatros Kunkannennen aka megulon-7....w 60-2...................NO
11. Brian Smith aka brian smith...LH2.4 - Normally Aspirated, clutch type undetermined as of yet........YES
12. Pat Darrow ....w/o 60-2.......................NO
13. Arne Saevik aka surre_sprett...BMW Pressure Plate.w/60-2...........Javisst, pengar är här
14. Dan Halli aka dhallilama..Saab 9000 pp, no 60-2.............NO
15. Chris Floren aka Duder...w 60-2..................YES
So anybody HERE need to get on the list?
Edited 7 time(s). Last edit at 10/06/2011 10:34PM by john vanlandingham.
Duder
Chris Floren
Re: Round 2 JVAB steel flywheels for Volvo
September 29, 2011 12:33AM
$100 deposit sent via paypal...and I signed up for this forum just to say so!
Maybe I'll have to start spending a bit more time around here now...
SteveL
Steve Leitch
Can't decide which to use...
September 29, 2011 12:47AM
Duder
Maybe you should read this and fill out your profile...
http://www.rallyanarchy.com/phorum/read.php?8,41104
SteveL
October 03, 2011 01:27PM
7 out of 15 so far, gotta crack the whip....
October 03, 2011 10:58PM
Deposit on these is $100 correct?
October 04, 2011 09:24AM
Yeah more or less.
October 04, 2011 03:57PM
Check for deposit (plus boinger dough) sent to JVAB at address listed on your website.
Magnum TE
Toby Eidelman
'92 Volvo 940T (tarmac dweller)
October 13, 2011 01:08AM
just spent like 2 hrs reading threads on TB about PP options, and now my brain hurts.
John can you recommend a tea for me to help with this headache. ^_^
Oh and hi Rally Anarchists!
Edited 1 time(s). Last edit at 10/13/2011 01:09AM by Magnum TE.
October 13, 2011 01:39AM
02. Hallvard Buer aka RS1..w 60-2 and custom bolt circle...............YES
07. Taliessin Penfound aka vertigosity..(2)..w 60-2......................YES
10. Albatros Kunkannennen aka megulon-7....w 60-2...................YES, sponsorship
12. Pat Darrow ....w/o 60-2.......................YES
14. Dan Halli aka dhallilama..Saab 9000 pp,........... YES[[/b]
16. Toby Eidelman aka Magnum TE......Kennedy 228 w/o......YES
17.Simon Babbs aka sbaabs..........w/60-2YES
Updated.
Edited 7 time(s). Last edit at 10/24/2011 01:45PM by john vanlandingham.
October 27, 2011 09:59AM
Welcome to the asylum itinerant Turbobrickers---plus any rally-Volvo pervs
18. Preben Thunberg--Norge..........?.......................Jovisst
19. Brian Havinga aka twofast242GT......60-2.......YES
20. Dennis Havinga ..aka.."Dad"........9000 60-2.........YES
Updated.[/quote]
Edited 2 time(s). Last edit at 11/06/2011 03:29PM by john vanlandingham.
October 27, 2011 11:03AM
So I am feeling nervous that I am just one of two that are not asking for the 60-2. I am planning on running Lh2.2. on a B23 block. 60-2 is only for 2.4 with the head mounted dizzy, correct?
Would I need the 60-2 in the future if I went with standalone? would I be able to run 2.2 with the 60-2 holes?
Ease this youngin's worried mind. Learn me
fidel
lawrence knox
78" volvo 242
October 28, 2011 09:33AM
volvo LH2.4 uses the 60-2 for the crank signal, and it uses a head mount dizzy on a 740 and a block mount on 240.
you can't run LH.2.2 off of a 60-2 signal, it uses a 4 window hall effect in the dizzy. it would not hurt anything to have the 60-2 flywheel for EFI upgades down the road. with the b23 block you will have to do some machining to mount the factory sensor bracket to the block, or weld a mount to the bellhousing for it.
trigger signals for standalone EFI systems varies. electramotive is only setup to use 60-2 for the crank signal, were other sytems can be configured for 4 window hall efect, 36-1, etc. if you go to a sequential setup you will also need a cam signal, there arn't any factory options for this if you have a 240. if you have a 740 a 2.2 740 dizzy can be modified by cutting off 3 of the 4 tabs on the tone wheel. there are other options for crank and cam signals aswell. there is a DSM cas adapter that goes were the block mounted dizzy goes (it can be used for both crank and cam signal). there are also edis trigger ring (36-1) adapers for the crank pulley . you could also fab up sensors to work of of the cam gear, crank pulley and/or flywheel with magnetic sensors.
October 28, 2011 09:40AM
Thanks Lawrence for the clarification. I'll put you down for 5 flywheels, OK?
November 05, 2011 11:17PM
List updated.
November 21, 2011 11:00AM
John,
Change up dat der list to include me in the 60-2 holes.
Danke
