Buy, Sell & Trade
Magnum TE
Toby Eidelman
'92 Volvo 940T (tarmac dweller)
Re: Round 2 JVAB steel flywheels for Volvo
May 31, 2012 06:43PM
Those 'coil overs' are going to be great! confused smiley My spring choice, maybe not so great.
I like to play with cars, it's very inappropriate.
Magnum TE
Toby Eidelman
June 01, 2012 03:22PM
John Here's the thread I made on TB
http://forums.turbobricks.com/showthread.php?p=4193717#post4193717
June 01, 2012 05:43PM
Magnum TE
Thanks man..
Seems the main requirement for moderators is that that should never write a word of advice or do anything useful for the fiorum or the community..
I'm sending some stand offs and stuff today to go with the flywheel.
Piccies to follow.
Magnum TE
Toby Eidelman
June 01, 2012 06:09PM
if that's the case I should have been a mod a long time ago.
June 01, 2012 06:22PM
Magnum TE
Doood look at the sidebar thing! You're a MEGA MODERATOR!
How does this forum go on for years with no "Moderators" with only 2 guys needing "termination"?
Edited 1 time(s). Last edit at 06/01/2012 06:23PM by john vanlandingham.
June 02, 2012 04:05PM
Just got my flywheel in the mail! Thanks John. Check. Now onto clutch and pp.
Zap zap my ass...
June 02, 2012 04:26PM
Is it purdy?
I have pressure plates right here.
You should be getting the stand off monday
it'll look like this
Edited 1 time(s). Last edit at 06/02/2012 04:29PM by john vanlandingham.
Magnum TE
Toby Eidelman
June 02, 2012 07:27PM
Hey John, I haven't been able to confirm this on mine (I'll check tonight) but...
http://forums.turbobricks.com/showthread.php?p=4195471#post4195471
surre_sprett;4195492
Sorry, I wish I could say that I were.. Also, the missing holes are in the wrong location, misses by 1/2"
Picture:
http://i.imgur.com/EiJmC.jpg
surre_sprett;4195471
Regarding the 60-2, there's made a terrible error, it is not 60-2 (58 holes w/ 2 holes missing), but 62-2 (60 holes), which renders this flywheel more or less useless!
How in the world can we solve this?
June 02, 2012 08:04PM
Magnum TE
Picture:
Holy shit.
Can't talk to the machinist who cut the holes till Monday, but there are already cars running with this from the first run.
It will be made right if these are in error.
Since there are cars now with them running, such as John McC in St. Louis then the first question is did they use the same CNC program---which we'd presume the did..
Same with the clocking...
Forward this if you would and I'm going to look at the sample---a flex plate left with them and some of the unsold ones...
I'll say frankly that I think the 60-2 on the flywheel is a pain in the ass system for anybody other than the original manufacturer----a nice easy access TDC senor aimed at the front pulley where a person can get at it and have some adjust-ability if needed seems to be a much more flexible system...
This does not bode well..
Magnum TE
Toby Eidelman
June 02, 2012 08:16PM
yeah I'll copy and post that up on TB. I'll check mine when I get home from work.
Personally I'm going to run a DSM CAS sensor inside the head mounted dizzy plate for my triggering needs. Seems to be a pretty cool setup.
Mylesofsmyles
June 02, 2012 09:50PM
Is this a non issue for those with a stand alone EMS?
Is it as easy as plugging in 62-2 vs. 60-2 or 58-2???
I don't understand?
Are there too many hole positions, or is the blank clocked improperly?
Mine was from the first round, and is now in the car, though I've not fired it.
JohnMC runs LH2.4 or did he just buy a flywheel with it..."just in case"???
June 02, 2012 10:26PM
Yeah PROBABLY
Yeas on most as far as I know, but I don't know what everybody is using especially the Norwegians.
I don't understand?
Me either. I left the sample flex plate, we measured the with of the tooth and measured the gap and I made big deal about clocking it.
Well the holes aren't that important, its the TEETH the sensor senses and there are 59 teeth and then the solid bit...whatver its wrong.
Yeah that's the screwy thing, his was on and running 2 days after it arrived...
I'm pretty sure there's others running..
We'll figure it out, just gonna cost some handfuls of hair. And a bunch of money.
Edited 1 time(s). Last edit at 06/03/2012 02:40PM by john vanlandingham.
Magnum TE
Toby Eidelman
June 03, 2012 01:31AM
From the TB thread:
Aaron Litz
Carson City, NV
Volvo & Kennedy 228
60-2
I don't need a clutch (or PP), just the flywheel.
Mylesofsmyles
June 03, 2012 01:53PM
Just posting this here, in case it'll help.
It's a stock flat flywheel that's had the LH2.4 cuts made...
Look at the blank spot, clocked, relative to the crank bolt holes.
Mylesofsmyles
October 23, 2012 09:11PM
The "Official" List for those that need a SOOper BITCHIN Flywheel...
As per NAME, LOCATION, P.P. PATTERN...
MYLES SAFFIAN - San Rafael, CA 94901 - SAAB 9000 240mm w/ 60-2 (I need a P.P. to go with it)
This is copied from TB
surre_sprett - Arne R. Saevik - BMW 228mm - w/60-2 -
aplitz - Aaron Litz - Volvo & Kennedy - 60-2
MagnumTE - Toby Eidelman - Volvo & KEP228
dhallilama - Dan Halli - SAAB 240mm
Duder - Chris Floren - SAAB 240mm w/ 60-2
Mattis - Mathias Mellum - SAAB 240mm w/ 60-2
vertigosity - Taliessin Penfound - Saab 240mm /w 60-2
vertigosity - Tom Penfound - Saab 240mm + Volvo 215 /w 60-2
Jerd - Jered Willhite - Vancouver Wa 98682 - Volvo & Saab 9000 228mm w/ 60-2
2fast242gt- Brian havinga 2x 60-2 drilled for the Kennedy plate (missing stand offs)
Sbabbs- Simon Babbs - SAAB 240mm w/ 60-2 (I want pressure plate also from you)[/QUOTE]
Edited 2 time(s). Last edit at 10/23/2012 11:34PM by Mylesofsmyles.
