Buy, Sell & Trade
WTB: 240sx Trans
Posted by 1fastben
1fastben
Ben Hetland
None, right now
WTB: 240sx Trans
November 01, 2011 12:50AM
Does anyone have one they want to let go of for uber cheap? My current one grenaded, (the kid I bought it from obviously beat the hell out of it) and the one I had as a spare, somebody STOLE! Which I just realized tonight. I think they snagged it when they came for the free grill I was giving away, just to get it outta the yard. Jerk-off pricks.
If you have one, or know of where I can get one for uber cheap, drop me a line. The ol' racing budget is down in the mid triple-digits, which is very worrying...
Anyway, have a good one!
Re: WTB: 240sx Trans
November 01, 2011 11:37AM
have you cracked the case to see what the problem is? It seems like, as long as the gears and shafts are intact and not damaged, you'd be better off rebuilding it rather than buying one in unknown condition.
Dunno if this link has any helpful info - blocked at work for me. http://www.nicoclub.com/archives/240sx-transmission-the-basics.html
This pdf has all the clearances etc - http://www.240edge.com/manuals/98_240sx/mt.pdf
November 01, 2011 04:06PM
Any way to go with a T5 instead? At least those are a dime a dozen and cheap! I got my close-ish ratio motorsport spec box for $600 shipped.
November 02, 2011 12:08AM
Integral bellhousings. It's probably easier to list the 3-4 Japanese boxes that aren't integral than those that are...
Now with a band saw and a donor case I know I could make it woik.
November 02, 2011 12:38AM
http://datsunzgarage.com/borg/
82-83 280zx turbo had a T5 apparently, and bellhousing from same allegedly bolts up to the ka24...
no idea if the gm T5 with the decent gearing would bolt up to the bellhousing though.
L engine from the 280 sits at a ~10 degree angle, and KA is vertical, so the shifter ends up a bit cockeyed.
also believe I saw a mention of having to do some hacking to make the starter bolt up...
November 02, 2011 12:52AM
If it actually bolts up KA24 and whatever the z-hell it was then get a bellhousing and case and a 380 gearset with very good ratios...Look for blather about boxes for Xratties and Volvos
Ian S
Ian Seppanen
1991 Nissan 240SX
November 03, 2011 12:51AM
I have a spare, but third gear grinds something furious, and my intent is to go through it, and repair the damage so I have a good spare.
I wish PPG didnt want $6000 for a gearset, ish.
Just out of curiosity, what were you running for gear lube?
I ran Amsoil at the first event, and the trans went from iffy to no bueno.
For LSPR I swapped in my spare, and it went from fine to borderline iffy. I am currently running RedLine.
1fastben
Ben Hetland
None, right now
November 03, 2011 09:32AM
I'll keep a lookout for the zx trans, and probably rebuild this one if possible later. I found a guy who might have a ka24 pickup trans, which is supposed to bolt right up, and is just a smidge shorter than the longest 240sx trans, which is fine. Plus it has more robust bearings.
Here's the gearing for the truck trans. It's decent, no T5, but decent. The jump from 1st to second is better than the 240sx at least.
Pickup:
1st.... 3.592
2nd.... 2.057
3rd.... 1.361
4th.... 1.000
5th.... 0.813
rev.... 3.657
240sx:
1st... 3.321
2nd... 1.902
3rd... 1.308
4th... 1.000
5th... 0.759
Anyway, I was running Lucas HD oil in it, FWIW.
Edited 1 time(s). Last edit at 11/03/2011 10:24AM by 1fastben.
November 03, 2011 10:29AM
I have a z wrecking yard just up the street from me, 4 acres of nothing but z cars. (you would have thought my dad had died and gone to heaven when he came to visit) You want me to see if he has a bellhousing lying around?
November 03, 2011 10:37AM
Also check the local recyle yards if you have them there. We constantly see briar covered old rigs heading that way. Someone stopped by last year with a nice old Datsun 1300 PU shell going that way. sad to see.
RallyxPOS13
Matt Miller
rallycross Nissan 240SX
November 03, 2011 10:42AM
I have no firsthand knowledge, but from what I've been told by a friend who tried to put a 240SX trans onto a truck:
-The truck transmission is short enough to be significant. (Pictures? http://forums.nicoclub.com/240sx-trans-into-hardbody-t394307.html )
-The shift isn't in exactly the same spot. (likely not a big deal)
-The starter holes are threaded on the opposite side. (which I think means you could keep the 240SX starter, and drill out the tapped holes on the truck transmission)
Anyway, worth looking into those points.
I foolishly gave away my pile o' transmissions when I sold my old 240SX, but I do see them pop up often enough on craigslist. I would be interested to see how well a T5 fits with the Z bellhousing...
November 03, 2011 11:05AM
Get as many as you can, you'll be fabulously wealthy!
You can finance a whole rally season!
Supply and demand.
Now we just gotta find cheap T5 boxes like sub $50 so it makes sense to throw in the right 2.95 first gearset....
Oh note well boys, a T5 can be the funnest box for mere hundreds but watch out for what 5th you choose, try and get a 0.72 or .78.
Alperti Kunkanenen got a Ford T5 in his mighty Volvo 240 and happened to get the 0.63 top gear and even with 4.88 axle that 5th is toooooo tall.
(with the indeterminate miles 2300 n.a. junk yard motor he has anyway)
All joking aside, it's worth making some effort to get a decent box with decent ratios---it is a central part of the drive experience and it can really make a car more funner-er, or be boring.
I say more funner-er is more fun.
1fastben
Ben Hetland
None, right now
November 03, 2011 03:33PM
A.J., yes, please take a look-see if there's a ZX box laying around! I'd totally appreciate it!
November 04, 2011 09:12AM
Get me Years, and trans code and I'll stop by tonight.
November 04, 2011 09:40AM
K I've had enough digging through drifter crap. 81-83 280zx turbo sound right to everyone?
