Buy, Sell & Trade
1fastben
Ben Hetland
None, right now
Re: WTB: 240sx Trans
November 04, 2011 10:16AM
I apologize, man, I totally didn't see that last post. Yeah, that sounds about right on the years, A+ for research.
November 04, 2011 10:22AM
K I've had enough digging through drifter crap. 81-83 280zx turbo sound right to everyone?
http://datsunzgarage.com/borg/ says 81 only came in auto, 82-83 is what you're looking for.
1fastben
Ben Hetland
None, right now
November 04, 2011 11:06AM
Hey...will this mean I'll need to have the driveshaft redone again to fit that T5, or will it be the same splines, anyone know?
November 04, 2011 11:18AM
In the crap I sifted through It looks like a new driveshaft is necessary. also saw some ruminations about input shaft length between the ford/chevy t5 and the nissan t5. could be worth some more digging,
November 04, 2011 03:04PM
1fastben
An Xratty buddy has 2 Z T5 and just asked him to check the splines vs the Ford and GM ones has laying around.
November 04, 2011 04:15PM
50$ for a bellhousing. Chatted the guy up for a minute or two, says nissan t5 bellhousing is not the standard t5 bolt pattern. Insert lots of bullshit here... back to useful info... 3 outta 4 bellhousings will bolt right up to your standard t5. the 4th requiring a little persuasion.... blah de blah...Says use gm clutch spline, nissan pp, flywheel TO bearing etc.
there is a core sitting in pieces in his shop, I can stop by early next week and take some measurements for you. Give me the measurements you want and make the instructions idiot proof.
1fastben
Ben Hetland
None, right now
November 04, 2011 10:01PM
Hmmm... I know the T5 is great for this application and will improve the car, but I JUST put a brand new clutch and flywheel on, and had the u-joints replaced on the drive shaft. Gotta say, even though it's better, I'm not willing to replace all that stuff again, nor can I afford it right now. I need to graduate and get a real job before I can afford to really do anything like that. I probably won't even be racing besides rallyX and the Utah rally sprint (hopefully) until then. sad smiley
But A.J., thanks for taking the time to check that stuff out for me, and for all your guys' advice. I don't mean to throw it away, I just can't afford it right now.
MRWmotorsports
Martin Walter
Nissan 240SX
November 06, 2011 08:46PM
I have 2 or 3 KA 5 speeds here in Otario, but that ain't much use when you are in Utah. Don't people swap in SR20's out there? Here they practically give aways KA stuff to get it out of the way.
I've run regular 80wt, synthetic, and redline in the last 6 seasons, swapped out the trans once because the input bearing was getting noisy... this is a SR trans, but they are the same except the bell housing.
-Martin.
November 07, 2011 12:33PM
No worries, if you ever change your mind shoot me a pm, if I can help I will.
saabman
John Kosmatka
Group 2 510 in progress
November 07, 2011 12:42PM
Interesting talk here. I have 82' ZX T-5 and plan on putting a ka24de into the 510. Time to start researching 240sx trans specs...
