Buy, Sell & Trade
Bay area BMW compact
Posted by NoCoast
November 25, 2011 07:52PM
http://sfbay.craigslist.org/eby/cto/2720332128.html
Re: Bay area BMW compact
November 25, 2011 08:12PM
Why not post how much it is?
Only a few little typie typies
November 25, 2011 09:11PM
How's this:
If you sell $600 of parts off this car, you could be as cool as that other guy.
November 26, 2011 11:39AM
Man. I need a more sensitive timer. It's somewhere in the 0-2 second range to click the link and open the ad...
It's $1100.
There's a 95 M3 part out on 318ti.org forum with engine/trans for $3k.
JVAB has already done shocks and struts for these.
Dave's learning all the intricacies.
November 26, 2011 11:45AM
It's $1100.
Dave's learning all the intricacies of why he maybe should have kept that little 1.9 16v and built it up since it seems that the 4 cyl 16 was made to rev and the giagantor heavy 6 cylinder is a time bomb above 4800 rpm, like bummer mang.
Yeah that what I was-a-stinkin too.
November 28, 2011 11:43AM
It's $1100.
Bullsh!t. If I wanted to rally something with 130hp and equally unimpressive torques I could've bought a golf.
Also, $3k is probably more than you need to spend for an M3 drivetrain. Its what I paid, but I was a BMW newb back then. Do make sure if you get a 1995 that you replace the weak shit in the head and secure the oil pump nut.
November 28, 2011 12:51PM
It's $1100.
Dave Dave Dave. Bore that little 1,9, get the compression up to about 11.6-11.8:1 and you can haz torques too, Then gear it shorter and it'll pull fine.. ay 180 ft/lbs and a 5. something axle, 1/2 the engine weight...
A custom CP piston set is about $700 bucks, cams can be had, and some management.
Easy!
November 28, 2011 01:21PM
I rather liked the 3.0L M3 engine in the car myself.
Rev limit to 6800 or so to be safe?
November 28, 2011 01:39PM
Maybe 4800 to be safe.hot smiley
November 28, 2011 04:57PM
Easy!
I've already gone down that road with the Evo. I wanted to stay as close to stock as possible on this one, including ECU stuff, and 91 pump gas. I purposely bought 1995 because it was the last year of OBD-1. Sure, my desire to avoid a built motor may not be "rational" but I know myself, and once I open the engine up, the damn thing will snowball into something way more expensive than the used S50 motor...and if you think building an Evo motor is expensive, these BMW shops see you coming from a mile away!
IIRC, the S50 is a 300 lbs motor, and the M44 is 225 lbs. Sure that extra 75 lbs is all out past the front shock towers...but it was a simple swap...and had I known a few extra things about the weak points of the S50, it could've been reliable. Hopefully it will be soon.
November 29, 2011 11:32AM
November 29, 2011 01:04PM
The problem with a failed head gasket on a BMW engine is they like to pull threads out of the block (aloy engine only) pretty sure those 4 bangers are Iron though...
November 29, 2011 01:05PM
The problem with a failed head gasket on a BMW engine is they like to pull threads out of the block (alloy engine only) pretty sure those 4 bangers are Iron though...
Yep. And a cute little steel crank..
November 29, 2011 01:46PM
Those alloy motors are too fancy for us rally types. smiling smiley
November 29, 2011 03:49PM
But but but the new Evobitchi X motor is now all alloy!
