With my motor now set in place, it's time to fab up a pair of motor mounts...
I've got some ideas, and some materials to work with, however I lack the essential skills & welder, to actually get it done. Since I'm swapping to a 2.3L Volvo 4-cylinder engine, this swap lacks a lot of the spacial complications with some of the more "exotic" swaps....what I've got going on, is rather simple. Anyone, local to me, interested in helping out? |
Magnum TE Toby Eidelman Junior Moderator Location: Santa Rosa Join Date: 10/12/2011 Age: Midlife Crisis Posts: 57 Rally Car: '92 Volvo 940T (tarmac dweller) |
Do you need the fab work done on site or can you make up a blueprint of what you need?
I've got connections up in Santa Rosa for fab work, but I doubt they want to drive to San Rafael, I can ask around if ya want Myles. I like to play with cars, it's very inappropriate. |
Make a design you have lotsa flexibility with. Maybe have somebody do the parts and you do the final drilling of the holes so you don't have to have the whole car there.
But that would be the best way: car on site.. You going to mount it to the crossmember? Have you think about doing like the later 940s? mounts---> o--I I--o Search piccies of "Ford Escort World Cup crossmember" John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 12/06/2012 05:48PM by john vanlandingham. |
Steering shaft is acquardly in my way...I should post you some detailed shots.
Thinking something like this'd be bitchinn... The bosses for the O.E. Volvo mounts, are right above the flat part of the subframe.... I thought I'd make a plate to bolt to the engine, with a tube, to press the bushing into, then weld the receiving end, straight up, from the subframe. Any reason I shouldn't stand that square tube w/ Bushing "Straight-Up" from the Subframe, so the receiving cup, on the motor just drops on, and then thru-bolts together? Hopefully, it'll classify as cheap, effective & simple Edited 1 time(s). Last edit at 12/06/2012 05:56PM by Mylesofsmyles. |
Ken Rogers Ken Rogers Elite Moderator Location: San Francisco Join Date: 08/17/2008 Age: Fossilized Posts: 45 Rally Car: All of the below ------> 71 145S-72 ES-82 245 GLT |
Looks like some torque rod ends and a couple U brackets you could cut out of U channel. Heck you could add a couple of gussets to the torque rod legs where they hit the X member, and have the cat's meow. 1971 145S - 1972 1800ES - 1982 245 GLT Edited 1 time(s). Last edit at 12/06/2012 11:40PM by Ken Rogers. |
As always, I admire your ability to find a good old Volvo part and recycle it, but the overall diameter of the Torque Rod Bushing, and it's sleeve is much too large for the space I have available.... Well, it is worth a second look....though the mounts I pictured do have a smaller outer diameter than the torque rods. |
Actually I was thinking about the early style with the one inch Ø hard rubber bushing. That don't wear out, but nobody wants because it's 'NOT POLY' garbage with half the lifespan of the OE OG rubber. 1971 145S - 1972 1800ES - 1982 245 GLT |
That was a good lil' chat on the phone.
I love the idea, and the fact that the parts are already in the "Bat-Cave" I'll lop a pair of brackets off a 240 rear axle, to have welded on to the motor mount brackets.... Maybe we'll be able to bolt these in, and go, go go! |
Hey kid, for reference the bush that Ford uses on the Sierras is a 79-82 Escort front leaf spring bush for vans. Its in a steel case 1.3" OD, 2.315" long, 12mm hole, and the rubber part is about 1.23 diameter.
A 4x4 with the front 7.5" diff weighs maybe a bit less than a Redblock so if that size is good enuf for a 4x4 weight it should be fine for a Redblock. They last forever and little vibration in the car. Nobody ever commented that they noticed bad vibes. I'd shoot for something at least that size. WE've use some Chebby leaf spring bush in the past on a 510 that got a truly Soooooper Bitchin motor called the FJ20, Nissan's copy of the Ford Cosworth BDG 2,0 16v. Worked fine John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Go big or go home! I'll measure the torque rod bushings, Ken speaks of, and see how far off we are. There's inherent benefit for me to pull just another part from the glorious Volvo parts catalogue, if I can. Not to mention, recycling parts, Ken has tons of, and won't throw away, so we can have parts for occasions like these... WE've use some Chebby leaf spring bush in the past on a 510 that got a truly Soooooper Bitchin motor called the FJ20, Nissan's copy of the Ford Cosworth BDG 2,0 16v. Worked fine[/quote] Ohhhh, ahhh... Just took a lap around the block, so my dog could make another steaming pile... Observed the new neighbor is a car guy...has a matte black, caged Wide Body 510, down LOW on some cool, Kelly Green wheels, and some nice, authentic Recaros. |
