Buy, Sell & Trade
El Cheapo Beemer Compacts in SoCal
Posted by RALLYRS
RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
June 23, 2014 07:11PM
Cheap.. although at least one of them is autotragic.....
Hard to find manual trans cars around these parts.....
http://orangecounty.craigslist.org/cto/4506257632.html
http://losangeles.craigslist.org/sfv/cto/4514858526.html
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
Edited 1 time(s). Last edit at 06/23/2014 07:12PM by RALLYRS.
Re: El Cheapo Beemer Compacts in SoCal
June 23, 2014 07:26PM
Now those are good links..$400 is great----cheap enough to do some stuff..
One of those 16v 4s fersure can be built make so OK powerz---and a little creative work can get a box with good ratios behind it...
RALLYRS
Mike Ball
June 23, 2014 09:29PM
Yeah...like you,I'm really not a BMW guy, but neighbor has one (semi-beater condition 318ti)parked outside and something about the compacts is intriguing.....
And I like the idea of keeping the lightweight 4 banger too- but damn it's hard to find ways to make it get out of it's own way without a used(discontinued) supercharger kit or a home brew turbo.
A whopping 138 hp....
Maybe figure out a homebrew itb set-up ,a tuning solution and throw some gearing at it?
Here's an article on final drive I found:
http://www.318ti.org/notebook/diff_conversion/
But if the automatic 318ti's came stock with a 4.44 final drive,I wonder why don't people just put those in the manual trans cars?
Post up Here:
and here:
Edited 1 time(s). Last edit at 06/23/2014 09:41PM by RALLYRS.
mellow65
Oliver Klozoff
Nada
June 23, 2014 10:41PM
Holy craps, did not know the e36s where getting that cheap!
RALLYRS
Mike Ball
June 24, 2014 12:35PM
mellow65
Yeah I dont usually see them this cheap.. a semi local search shows private party cars right now at $2100 ,two at $3000, and one at $4600 and one at $4900.
Thats More typical pricing when I search....
Even then ,many of these cars when I search for them often are salvage ,and even though some of them are modded- here in LAlaland easily 75% of them are slushboxessad smiley
Post up Here:
and here:
June 24, 2014 01:47PM
We've got four of them around that were bought for 500-1200.
2.8L OBD2 swaps with M3 cams are plenty.
There are two diffs, small case (~6.8" ring gear) and medium (8"winking smiley. The four bangers have the small, six have the medium. 4.44 is only small case. 4.10 with LSD is best stock option for these.
We'll have rear turrets done within next couple weeks for these. Quite a few other things we are working on specifically for the Compacts.
Will have a rental Compact available next summer.
RALLYRS
Mike Ball
June 24, 2014 02:16PM
So Grant -for a race car the small case is weak and should just be avoided right?
Particularly if you are upgrading the engine Horsey's substantially from the awesome stock 138 hp?
Post up Here:
and here:
June 24, 2014 03:09PM
RALLYRS
Small case
Uh, duh.
RALLYRS
Mike Ball
June 24, 2014 03:18PM
Wow that just slightly came apart-huh?
Post up Here:
and here:
June 24, 2014 03:28PM
Small case an embarrassingly miniscule 168mm aka 6.6"
Medium case ...An OK for low powered n.a. cars maybe safe for 200 ftlbs 188mm aka 7.4" (compare DANA 30 at 7.2" or stock Xratty at 7.5" )
Large Differentials 210mm--a nice strong 8.27"....
Generally used behind early M5, M6, V8,
V12, some early 7 Series and E 46 M3 engines
As with everything on BMWs I say "Got a 320 E30?...move up two steps on everything for rally"
Of course no alternate ratios that are any good for the large case ones leaving the just barely enough for 190 ft/lbs but probably undersized for the 3.0 24v variocam thing
Certainly could help to make the solid spacer mod and ditch the collapsible spacer on the pinion..
June 24, 2014 03:29PM
RALLYRS
Modern stuff. Just enough for whatever they decided the car is intended for..
June 24, 2014 05:30PM
Small case is fine. Ask Jari.
June 24, 2014 06:41PM
If you insist. I like nice safe margins...and I like choosing good ratios without going bankrupt.
Maybe I can re-find that place I got the photo and you can tell them that that diff is fine...
RALLYRS
Mike Ball
June 24, 2014 07:20PM
Yeah nothing a spackling knife and and some jb weld couldn't fix......
Post up Here:
and here:
June 24, 2014 07:58PM
RALLYRS
It's fine.. BMW are perfect in every respect. oil pump failures, valve locks failing and dropping valve , cast iron lower shock single shear mounts snapping off right and left, diffs breaking in half, ring and pinions shreading teeth all over....all owner/operator errors.
That diff is fine.
Edited 1 time(s). Last edit at 06/25/2014 10:01AM by john vanlandingham.
